The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 9000, ISO 9001, and ISO 9004 - Quality Management Systems > ISO 9000, ISO 9001, and ISO 9004 - Questions and Discussions
Elsmar Cove Forum Sidebar
Custom Search
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Atul's
Symphony Technologies
SQR Consulting
Bob Doering's
Quality Digest Portal
  #1
Old 27th October 2009, 09:32 AM
Magirus Magirus is offline
Inactive Registered Visitor
Registration Date: Oct 2009
Thanks Given to Others: 0
Karma Power: 15
Magirus has less than 100 Karma points so far.
Please Help! ISO 9001:2008 vs. ISO 10012:2003 - Can anyone expain the need for 10012:2003
Can anyone expain the need for 10012:2003?
Since, if you follow the requirements in 9001:2008 you will also fulfil all requirments in 10012:2003.
And since the reference as guide in ISO 9001 have been removed and it is not supposed to be a stand alone document, I do not see the intetion any longer with this standard.
Br
Magirus
  #2
Old 27th October 2009, 11:33 AM
suffelde suffelde is offline
Involved in Discussions
Registration Date: Nov 2006
Thanks Given to Others: 14
Karma Power: 29
suffelde has less than 100 Karma points so far.
Send a message via Yahoo to suffelde
Re: ISO 9001:2008 vs. 10012:2003
The primary need is going to be if the standard is called out on a P/O or contract. There is no specific requirement in the standard that requires any particular standard whether it be 10012 or ANSI Z-540. 17025 might come into play for certain industries, but the best thing to do is look at your customer requirements, make sure you have traceability, uncertainty and correction factors are applied, etc.
Dave
  #3
Old 27th October 2009, 03:14 PM
Karma Power: 15
Thanks for the quick response; But I am in the System Audit business and would like to know what if there is anything more (Specific) I can expect from a company that claims compliant with ISO 10012:2003 compared to a company only comliant with ISO 9001:2008
Br
Magirus
  #4
Old 27th October 2009, 03:16 PM
howste's Avatar
howste howste is offline
Thaumaturge
Registration Date: May 2003
Thanks Given to Others: 992
Karma Power: 484
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
In Reply to Parent Post by Magirus View Post
Like any other standard that's not a requirement, you can use it for guidance. It represents good practice for measurement processes and equipment.
Not true. ISO 9001 gives very vague requirements for measuring equipment, while ISO 10012 gives more specifics.
For example, ISO 9001 says "The organization shall determine and manage the work environment needed to achieve conformity to product requirements." ISO 10012 says "The environmental conditions required for the effective operation of the measurement processes covered by the measurement management system shall be documented.
Environmental conditions affecting measurements shall be monitored and recorded. Corrections based on the environmental conditions shall be recorded and applied to measurement results."
Another example: ISO 9001 states, "...measuring equipment shall be calibrated or verified, or both, at specified intervals...." ISO 10012 states, "The methods used to determine or change the intervals between metrological confirmation shall be described in documented procedures."
These are just two examples of many that show that conformity to ISO 9001 does not guarantee conformity to ISO 10012.
I don't see where it says it can't be a stand alone document. It says it's "not intended to be used as a requisite for demonstrating conformance with ISO 9001, ISO 14001 or any other standard" This means it's not mandatory for ISO 9001 or 14001, but it doesn't say any ways it can't be used.
It can be used as a guidance document. In fact it says "It specifies the quality management requirements of a measurement management system that can be used by an organization performing measurements as part of the overall management system, and to ensure metrological requirements are met."
Thanks to howste for your informative Post and/or Attachment!
  #5
Old 27th October 2009, 05:30 PM
Karma Power: 29
Re: ISO 9001:2008 vs. ISO 10012:2003 - Can anyone expain the need for 10012:2003
Even from a systems audit point of view, if the QMS states they are compliant with the 10012 standard, then the standard becomes a part of their QMS. In this event, they should have as one of their external documents this standard and be able to show evidence of the standard.
It is not uncommon to see this standard on a P/O or Contract. Therefore there is an audit trail to the 7.0 of the 9001 standard. Also, it would flow down to calibration vendors.
As I recall, this standard replaced the Mil Q 45662A since the military made it obsolete. Just like the post above, you can see that it gives guidance on the management of the metrology system.
Let me know if this is stuff you already know or not or if you want more info.
Dave
Smilies are On
ISO 10012:2003 - Interpretation of Managment Responsibility clause Laurie Wright Other ISO and International Standards and European Regulations 1 23rd November 2010 09:37 AM
Demystifying ISO 10012:2003 - Measurement Management Systems qualitygoddess - 2010 Other ISO and International Standards and European Regulations 4 16th March 2009 01:06 PM
ISO 10012:2003 question (Confirmation ID) lianayada ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 2 11th October 2007 12:16 PM
ISO 10012 Part 1 (replaced by ISO 10012:2003) and Part 2 km2red ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 3 18th January 2007 04:01 AM
ISO 9001:2000 vs. ISO 10012:2003 Procedure and Related Requirements António Vieira ISO 9000, ISO 9001, and ISO 9004 - Questions and Discussions 6 26th October 2005 03:17 PM
The time now is 04:21 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
