To respond to the clause, you could also split product audit, depending on your business and processes.
For example, in product audit in the dock, before shipping, you can audit packaging and labelling, also checking enclosed documentation. Clearly using sampling technicques.
Dimensions and functionality could be audit in indirect way , checking at results of parametric and probing test, correlating the data on problems of product dimensions and functionality. This could be the case of an electronic business.
hope this helps.
In Reply to Parent Post by Andrews
Mr.peteroldfield,
The form posted by you seems to be for process audit. Product audit as per TS2 clause 8.2.2.3 requires "The organisation to audit products at appropriate stages of production and delivery to verify conformity to all specified requirements , such as product dimensions , functionality, packaging and labeling ....".Your form does not cover product dimensions , functionality, packaging and labeling.
Regards
