Elsmar Cove Forum Sidebar
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Atul's Symphony Technologies
Quality Digest Portal
12th April 2012, 06:52 AM
Involved in Discussions
Registration Date: Nov 2008
Thanks Given to Others: 41
Karma Power: 29 Karma: 143
How many batches have to be kept under Stability Studies
The query is related to API (Active Pharmaceutical ingredient)
There is a change with respect to input batch size. Proportionately the other raw materials will also get increased.
Except the scale change there is no change in the process.
Hence, it is decided to go for validation.
The query is how many batches have to be kept under stability studies (from the scale up)?
All the validation bathes needs to be kept under stability for both conditions or one batch from the validation batch under long term condition is enough?
Is there any guideline reference for this?
Regards / Raghu
12th April 2012, 07:41 AM
Glad to help, if I can
Registration Date: Mar 2010
Thanks Given to Others: 1,355
Karma Power: 168
Re: How many batches have to be kept under Stability Studies
In Reply to Parent Post by raghu_1968
Regards / Raghu
Does this help?
http://www.ich.org/products/guidelin...uidelines.html
BTW, if the scale change is anything but very minor, don't automatically assume that keeping all ingredients in proportions will suffice. You may be up for some surprises concerning uniformity / consistency, heat effects etc. If the costs of making a full scale batch is high, you might want to reconsider going straight to validation, because you may have to dump some...
Thanks to Ronen E for your informative Post and/or Attachment!
12th April 2012, 11:46 AM
Forum Administrator
Registration Date: Dec 2005
Thanks Given to Others: 1,481
Karma Power: 400
Regards / Raghu
In case of scale-up, there is definitely a great impact on lending operations and thus I would still go with 3 initial batches for Stability.
Regarding guidelines, Q7A would be still a great reference. Refer HERE
__________________
Well done is better than well said - Benjamin Franklin
Thank You to Ajit Basrur for your informative Post and/or Attachment!
16th April 2012, 05:20 AM
Q7A states as below:
“Normally the first three commercial production batches should be placed on the stability monitoring program to confirm the retest or expiry date. However, where data from previous studies show that the API is expected to remain stable for at least two years, fewer than three batches can be used.”
As mentioned earlier, except scale-up there are no other changes. Is it acceptable to have a single batch on stability from the scale up batch?
16th April 2012, 06:10 PM
Forum Administrator
Karma Power: 400
You could but have to provide a solid rationale. Three is an acceptable number to FDA and other regulators and hence I prefer 3 batches.
Its your call
__________________
Thanks to Ajit Basrur for your informative Post and/or Attachment!
16th April 2012, 06:44 PM
Karma Power: 168
...However, where data from previous studies show that the API is expected to remain stable for at least two years...
Q: Do you have such data?
My A: No, because apparently previous studies were done on the smaller scale batches. I don't know your processes, but from my limited experience significant scale-up must not be automatically assumed to behave "linearly".
28th April 2012, 01:01 PM
Appreciated Information Resource
Registration Date: Jan 2009
Thanks Given to Others: 93
Karma Power: 82
I agree with Ronen & Ajit...
what i would like to add is , the emphasis&need on risk assessment; (solid rationale...)
usually the manufacturing process includes atleast couple of steps; if the batch size is increased for 1-step...and process rest of steps unchanged (lot wise processing).
even then we have to establish the effect of hold time of each lots...etc.,and its impact on rest of the product...
hope that helps.
| Thread Tools |
Search this Thread |
| Display Modes |
Rate Thread Content |
Linear Mode
