Elsmar Cove Forum Sidebar
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Atul's Symphony Technologies
Quality Digest Portal
21st April 2012, 02:12 AM
Involved in Discussions
Registration Date: Feb 2011
Thanks Given to Others: 1
Karma Power: 11 Karma: 10
Cpk - How to calculate when the number of samples is less than 30 pieces?
How is calculated When the number of samples is less than 30 CPK ?
Excel software to do this work?
21st April 2012, 04:02 AM
Quality impulse
Registration Date: Jun 2007
Thanks Given to Others: 36
Karma Power: 26 Karma: 30
Re: Cpk - How to calculate when the number of samples is less than 30?
If you talk in a sample (units) size may be some one expert can support you
IMHO the CPK is pertinent by subgroup size, Sub group Frequency and the last is Number of supgroup and Generally the number of subgroups is 25 or more..to get the good test for stability,
excel able to this job.
21st April 2012, 05:18 AM
In Reply to Parent Post by harrysons
stability,
My number for the CPK is 20 pieces. Not twenty-subgroup
21st April 2012, 05:24 AM
Cpk
How is calculated CPK When the number of samples is less than 30 Pieces ?(My number for the CPK is 20 pieces. Not twenty-subgroup)
THANKS BABAK MAGHSOODIAN
21st April 2012, 06:49 AM
Registration Date: Sep 2005
Thanks Given to Others: 1,402
Karma Power: 661
Re: Cpk
In Reply to Parent Post by maghsoodi
Welcome to the Cove.
There is no need for a new thread as the original thread title had been edited to clearly reflect your situation - less than 30 pieces.
Weekends are typically slow so please be patient. The crowd will be back by Monday morning, US time.
21st April 2012, 11:15 AM
Cross Forum Moderator
Registration Date: Jan 2005
Thanks Given to Others: 1,778
Karma Power: 1444
Re: Cpk - How to calculate when the number of samples is less than 30 pieces?
You can't derive a legitimate Cpk number from a sample of 20 pieces or 30 pieces or 100 pieces, for that matter.
Cpk assumes:
- A statistically stable process
- Rational subgrouping and chronological sampling while production is running
- A large enough number of measured subgroups to represent the expected output of the process over time.
Cpk is not a very meaningful index under the best of circumstances, but unless the conditions above are fulfilled it's pretty much a waste of time.
__________________
We aim to please. You aim too, please.
Thanks to Jim Wynne for your informative Post and/or Attachment!
22nd April 2012, 11:25 AM
Appreciated Information Resource
Thanks Given to Others: 66
Karma Power: 52
Here is some info on Cpk.
http://www.itl.nist.gov/div898/handb...ion1/pmc16.htm
Having a stable process is a prerequisite and you cannot determine that from a single sample. Another important consideration is making sure your distribution is "normal" and your sample standard deviation (s) is a good estimate for the population standard deviation (sigma). Do not assume your distribution is normal/gaussian unless you test it, and a sample of 20 does not provide great power for that test.
Also note what is stated on the NIST link:
Most capability indices estimates are valid only if the sample size used is 'large enough'. Large enough is generally thought to be about 50 independent data values.
The math is the easy part.
Thanks to Sam Lazzara for your informative Post and/or Attachment!
27th April 2012, 09:02 AM
Registration Date: Mar 2002
Thanks Given to Others: 63
Karma Power: 99
Sorry for being a little late  , have been bussy.... but this other tread is good for the matter.
Sample Size Does Matter
On that post, I try to say, you can calculate with almost any sample size but, the important thing is What is the worst case value for such estimate. Maybe many of us like to show good numbers, but being real is important, and most of us take the estimates as the true value, not just an estimate.
There are other issues far more important than sample size, as is stated on this tread, the normality is the real deal, and sample size does not assure the Gaussian Distribution.
__________________
Vits er thorf, theim vitha ratar; daelt er heima hvat; at augabragthi verthr, sá er ekki kann ok med snotrom sitr.
| Thread Tools |
Search this Thread |
| Display Modes |
Rate Thread Content |
Linear Mode
