Our process saw problem differce surface of electronic part (Arm Damper) . Why it had differance surface (Found 12 by 1200 piece)
Stainless is material after stamping
Can you please provide more details? Do you guys manufacture the arm damper or are you receiving the defective one from your supplier?
Reason: grammar
We are manufacture arm damper sir. These came from customer complaint about differance surface. Process begin with stamping then cleaning ECD and Packing to customer.
It is not easy to spot the difference in so small a picture, but the surface of the abnormal arm seems to have more gloss. Is that correct?
Is there any tolerance for surface roughness or gloss level?
Does the surface in question have any practical function (other than holding the part together)?
Did you observe any difference in surface gloss on the raw material (i.e: did it appear during your operations or earlier in the process)?
