The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > General Metrology, Measurement Device, Calibration and Test Laboratories > General Measurement Device and Calibration Topics
Calibration of Load Cell using Compression Machine as Comparator
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Organization - ISO Standards and Information
Related Topic Tags
calibration procedures and methods, compression testing, load cells, calibration (general topics)
  Post Number #1
Old 28th April 2012, 08:07 AM
Squarepants
Question Calibration of Load Cell using Compression Machine as Comparator
Hi everyone,
Good day!
I'd like to ask to anyone who has an experience or knowledge in calibration of load cell. Is it possible to use the compression machine as a comparator for calibration of load cell in compression mode? because I have a customer that insisted me to do the calibration using compression machine.
We haven't any universal calibrating machine to perform the standard procedure for the load cell calibration. I am not sure if it is possible to use the compression machine as comparator. I can't imagine how I perform the hysteresis.
I know that this post is kinda non-sense but I just want to hear your opinion regarding this matter.
thanks & regards,
Squarepants
  Post Number #2
Old 29th April 2012, 05:13 AM
Stijloor's Avatar
Stijloor
Re: Calibration of Load Cell using Compression Machine as Comparator
A Quick Bump!
Can someone help?
Thank you very much!!
Stijloor.
  Post Number #3
Old 30th April 2012, 02:20 AM
Stijloor's Avatar
Stijloor
Again a Quick Bump!
Can someone help?
Stijloor.
  Post Number #4
Old 30th April 2012, 09:06 AM
BradM's Avatar
BradM
Hello there! Welcome to the Cove!
Now.... be patient with me as I try to understand your scenario.
You have a compression machine, labeled A. You have some load cells that are used on that compression machine, labeled B, C, D.
Your question stems around using the compression machine as a comparative device. Correct?
Does that mean using, B,C,D on A; or on another compression machine?
I guess I'm confused on exactly what you are going to be comparing. Do you have standard load cells you would use as comparison to B, C, D?
Sorry for all the questions. Just trying to get a feel for your scenario.
  Post Number #5
Old 30th April 2012, 06:59 PM
Hershal's Avatar
Hershal
Actually, the compression machine should function more as a faxture than standard. Typically, the master load cell (calibration standard) can be placed in series and then the machine operated. That way, both the standard and customer load cells receive the same compression at the same time.
You can use either set the force or follow the force methods.
You should use a load cell with at least the same capacity as the greatest load the machine can produce, and preferably higher.
Hope this helps.
Thank You to Hershal for your informative Post and/or Attachment!
  Post Number #6
Old 21st May 2012, 08:59 AM
Squarepants
In Reply to Parent Post by BradM View Post
Hi BradM,
thanks for the reply. Yes you are correct. I will use the compression testing machine as a comparative device. this is as per customer's request since they urgently need the calibration certificate for load cell. so they suggests to use their compression m/c as a comparative device.
Hi Hershal,
also, Thanks to your reply. that's the correct way of calibrating load cell according to iso 376. but since there is no available comparator or comparative device the customer suggests to use their compression machine. I think that is possible provided that the compression area is fit for two load cell with loading plate in between cells.
Smilies are On
Tolerance Estimation of a Load Cell I want to Calibrate casiano General Measurement Device and Calibration Topics 9 5th June 2015 12:42 AM
Force Calibration - In-House Load Cell Calibration wesatwork General Measurement Device and Calibration Topics 7 2nd June 2015 03:33 AM
Gage R&R on a Load Cell fixture that tests the resistance of a Headrest disaac Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5 26th February 2013 04:45 PM
Procedure for Calibration of my Load Cell Testing Equipment - Needed IronThorn General Measurement Device and Calibration Topics 5 9th November 2006 06:55 PM
Gage R&R for effort required to actuate the horn switch with a load cell MedinaJC Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7 9th February 2004 02:25 PM
The time now is 01:25 AM. All times are GMT -4.
