The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Manufacturing and Related Processes
Elsmar Cove Forum Sidebar
Custom Search
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Atul's
Symphony Technologies
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
coatings, testing (general testing topics), zinc phosphate
  #1
Old 29th May 2012, 05:06 PM
timber timber is offline
Shy Poster (1 to 5 Posts)
Registration Date: May 2012
Thanks Given to Others: 0
Karma Power: 4
timber has less than 100 Karma points so far.
Please Help! Zinc Phosphate Test Panels look bad - Need Help
Help we have a 10 stage zinc phos. system with a pickle stage i can not get good looking test panels all mech. issues have been solved ie drydown, porr cleaning etc the tanks are all in chem spec. temps are good all the known aspects are good nut the panels are still bad crs,and hrs look streaking like drydown or prephos. no idea on it i have even recived the msds on lube used on the parts any ideas,
  #2
Old 29th May 2012, 06:44 PM
Wes Bucey's Avatar
Wes Bucey Wes Bucey is offline
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 451
Karma Power: 1122
Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.
Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.Wes Bucey is appreciated, and has over 1700 Karma points.
Re: Zinc Phosphate test panels look bad - Need Help
In Reply to Parent Post by timber View Post
My only suggestion is to call the factory supplying your zinc phosphate chemicals. Supply good quality digital photos of the observed streaking. There is a high probability they have encountered something similar and will have suggestions.
More intensive research can be expensive by involving metallurgists and chemical analysis.
You refer to "test panels" - what is the final product to be coated? Will it be used as is or additionally painted? Is this an appearance item or strictly functional rust preventative on non-cosmetic components?
Is this an in-house process on your own parts or are you a metal finishing vendor providing service to other customers?
__________________
"Few minds wear out; more rust out"
Inscribed over the entrance of Louis Pasteur School, Chicago
Christian Nestell Bovee (1820-1904) in Thoughts, Feelings and Fancies, 1857
  #3
Old 20th July 2012, 12:15 PM
diptankd diptankd is offline
Involved in Discussions
Registration Date: Jul 2007
Thanks Given to Others: 35
Karma Power: 27
diptankd has less than 100 Karma points so far.
Re: Zinc Phosphate Test Panels look bad - Need Help
I had a simular problem. My cleaning tank was in spec but there was a build up of oil from the product in the tank causing streaking. I emptyed the tank and recharged it problem went away. You can try an activator in the rinse tank before it goes into the zinc tank that will help also. Good luck.
diptankd
Thanks to diptankd for your informative Post and/or Attachment!
Smilies are On
Easy Method to Test a Caliper - Good or bad? jane-hu ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 10 8th September 2010 01:05 AM
Salt Spray Test on 3 year old Zinc Die Casting Chromed part per ASTM B 117-03 jordigolo Manufacturing and Related Processes 2 5th October 2009 04:35 AM
Zinc Phosphate problems - Green Bath has turned White diptankd Manufacturing and Related Processes 11 28th August 2007 10:27 AM
Engineering Material Specifications - Paint (zinc phosphate) and e-coat shawnann Manufacturing and Related Processes 11 21st August 2007 12:16 PM
Operator Training sheet for zinc phosphate/chromate diptankd Training - Internal, External and Distance Learning 3 25th July 2007 12:01 PM
The time now is 04:43 PM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
