The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > National and International Business Standards and Requirements > CE Marking (Conformité Européene) / CB Scheme
Elsmar Cove Forum Sidebar
Custom Search
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Atul's
Symphony Technologies
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
iec 60601 - medical electrical equipment, low voltage directive 2006/95/ec
  #1
Old 15th June 2012, 10:26 AM
Pick 5 Pick 5 is offline
Shy Poster (1 to 5 Posts)
Registration Date: Jun 2012
Thanks Given to Others: 0
Karma Power: 4
Pick 5 has less than 100 Karma points so far.
Question IEC 61010 3rd Edition - When devices are listed to the 2nd edition
My company produces several kinds of borderline medical devices, most of which are listed to 61010-1 2nd edition. When the 3rd edition becomes mandatory for assumption of compliance to the Low Voltage Directive (Oct 2013), how do I show compliance when most of my models are listed to particulars which have not been uplifted to 2nd edition?
If a product is listed to a particular (i.e. 61010-2-010 or 61010-2-051) can I update to 61010-1 3rd edition?
  #2
Old 16th June 2012, 01:59 AM
Stijloor's Avatar
Stijloor Stijloor is offline
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 2,947
Karma Power: 1429
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Re: IEC 61010 3rd Edition - When devices are listed to the 2nd edition
A Quick Bump!
Can someone help?
Thank you very much!!
  #3
Old 18th June 2012, 04:18 AM
CharlieUK CharlieUK is offline
Involved in Discussions
Karma Power: 8
CharlieUK is appreciated, and has over 100 Karma points.CharlieUK is appreciated, and has over 100 Karma points.
You seem to be mixing some requirements/directives.
Equipment is either covered by Medical Device Directive, or it isn't - even if it's "borderline", it doesn't "sit on the fence", it falls under one or the other.
Fully Applying Harmonised Standards gives a Presumption of Conformity. When your existing Harmonised Standard is superceded, you are not actually required to do anything under LVD or EMC Directives (but might be under other directives) - you can choose to still declare to previous standard.
Should you wish to update to latest standard (and this would be the "recommended" approach) then check what has changed that applies to your product, perform any required tests, update Technical File and issue new DoC.
Since you're following CB scheme, also talk to you're test lab about when they will be able to assess to 3rd edition and give CB cert.
Thanks to CharlieUK for your informative Post and/or Attachment!
  #4
Old 18th June 2012, 09:39 AM
Karma Power: 4
Question Re: IEC 61010 3rd Edition - When devices are listed to the 2nd edition
Thanks for the reply. Let me clarify.
To meet he LVD, the 2nd edition of 61010-1 can no longer be used to assume conformity after Oct 2013. Is this correct?
If it is correct, what must we do with products which are listed to 61010-1 2nd edition, but can not be uplifted to 3rd edition because the coresponding particular is not available in 3rd edition?
Can I have a device listed to a base standard and the particulars listed to the preceeding edition of the base standard?
THanks in advance
  #5
Old 18th June 2012, 10:51 AM
Karma Power: 8
It won't give you a Presumption of Conformity - correct.
There are a number of changes between 2nd and 3rd editions, including:
  • Test and measurement circuit requirements moved to a separate part 2 standard IEC 61010-2-30
  • The scope now covers both professional and non-professional products
  • Rewritten clause regarding solid and thin film insulation
  • More detailed mechanical requirements
  • Temperature requirements modified due to EN563
  • X-ray requirements modified to include intended and non-intended emissions
  • Added requirements for foreseeable misuse and ergonomics
  • New requirements for risk assessment
  • New informative section on pollution degree and micro-environments
  • New requirements for conformal coatings
I don't know enough about your product to comment as to how these might affect you.
Did you do the initial safety assessment or did a 3rd party lab do it?
If lab - suggest you talk to them as they will have experience of you product.
  #6
Old 20th June 2012, 03:41 PM
Sarah Stec Sarah Stec is offline
Registration Date: Nov 2011
Thanks Given to Others: 12
Karma Power: 8
Sarah Stec has less than 100 Karma points so far.
I agree with CharlieUK to talk to your 3rd party lab (or a 3rd party lab) with whom you can share more information about your device. Generally, our stance is that if a standard that exists in the 2nd edition has not yet been translated into the 3rd edition format, the manufacturer should wait for the standard to be translated to see when is the date of cessation of presumption of conformity. Obviously, this has different implications that depend on the device and the standards you use. Your lab could also have information about when updated standards and how to handle them.
Smilies are On
IEC 60601-2-27 - Comparison of 2nd to 3rd edition thelastdon99 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6 15th June 2012 11:35 AM
Rework Devices placed on the market - IEC 60601-1 Requirements 3rd edition Mawos78 IEC 60601 - Medical Electrical Equipment Safety Standards Series 7 19th April 2012 02:55 PM
Acceptability of Existing Devices complying to IEC 60601-1 2nd Edition after Jun'2012 indorewalep IEC 60601 - Medical Electrical Equipment Safety Standards Series 6 2nd February 2012 05:46 AM
IEC 60601-1 2nd Clause 17 and 3rd edition - Electrical Isolation benjh IEC 60601 - Medical Electrical Equipment Safety Standards Series 3 19th October 2011 12:31 PM
Effects of the changes from 2nd edition to the 3rd edition on the calculation of GR&R zjp1339 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6 30th March 2006 12:55 AM
The time now is 06:08 PM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
