Elsmar Cove Forum Sidebar
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Atul's Symphony Technologies
Quality Digest Portal
27th July 2012, 08:16 PM
Shy Poster (1 to 5 Posts)
Registration Date: Mar 2008
Thanks Given to Others: 0
Karma Power: 21 Karma: 10
Measuring Scratches with a Surface Roughness Tester
The company I work for has a manufacturing process that is causing longitudinal and transverse scratches on the outside surface of a cylindrical, carbon-alloy part. The standard specification for this part defines the acceptable surface finish, but does not define acceptance/rejection criteria for discontinunities - like scratches.
Several people at my company and at a related company are wanting to measure the scratches using a surface roughness gauge (Surftest SJ-201P) to accept/reject the parts. My understanding is that this would be a misuse of the tester, because it is designed to take several samples of the surface roughness and provide an "average", essentially removing outliers like a scratch.
The conversation is not going well. Please help me explain why the surface roughness gauge is not going to work. Also, I am open to the possibility that I am wrong.
Secondly, I am setting acceptance/rejection criteria for these scratches (depth,width,length) and I am looking for a device that will measure these aspects. So far, I am looking at optical micrometers for measuring scratch depth? What can used to measure width?
Regards.
28th July 2012, 03:34 AM
Registration Date: Sep 2005
Thanks Given to Others: 1,406
Karma Power: 662
Re: Measuring Scratches with a Surface Roughness Tester
Welcome to the Cove.
Have a look at this to differentiate the definition of the 3 measures of roughness, Ra, Ry and Rz. Ry seems to be what you are looking for. It does not remove a scratch as an outlier but will indicate its presence by a higher average reading than one without any scratches.
28th July 2012, 10:55 AM
Registration Date: Jan 2004
Thanks Given to Others: 2,982
Karma Power: 612
Digital profilometers are designed to, as a rule deliver a reading that is the average of the profile readings taken over the length of the stylus's travel. My review of Mitutoyo's manual titled Surftest Measurement Surftest SJ-201/SJ-301 satisfies me that you are correctly describing the model SJ-201's limitations for measuring the scratches. The model SJ-301, with is digital and printable readout can show the heights that are being calculated for the average, apparently allowing an inspector to identify the individual profile readings (as described by the manual, to allow the individual readings to be excluded from the average).
__________________
"If you only have a hammer, you tend to see every problem as a nail." Abraham Maslow
Thanks to Jennifer Kirley for your informative Post and/or Attachment!
30th July 2012, 03:49 PM
Involved in Discussions
Registration Date: Apr 2011
Thanks Given to Others: 7
Karma Power: 14
There are many more surface parameters than Ra, Ry and Rz. If you look at http://www.mitutoyo.co.uk/Mit/downlo...e-overview.pdf you will see that there are a signifinant number of parameters that can be measured with the right device. A simple profilimeter may not be able to do what you need but if you check with manufacturers and not just Mitutoyo, I'm sure that for a price you can find a way to measure your surface. You just have to decide what is the right prices for your inspection requirements. Hope this helps.
23rd October 2012, 03:38 AM
Registration Date: Sep 2012
Karma Power: 3 Karma: 10
Hi Guys,
My boss has just asked me to recommend him a method of checking Ra 0.4um considering the parallelism with 5um. This is for the lapping process that the part is going through. It will be great if someone can help here. Attached is the prints for further info.
Kumar
| Thread Tools |
Search this Thread |
| Display Modes |
Rate Thread Content |
Linear Mode
