atetsade said:
1. Basically can you do graphical inspection analysis without a paper graph?
--Erik
I guess you could but then would it be graphical inspection analysis?
atetsade said:
2. Are there cases where precision graphing is required, such that drafting tools used in paper gaging need to be calibrated and their measurement uncertainty estimated?
--Erik
Not that I'm aware of. This subject is covered by Foster in “Geo-Metrics III” , Meadows in “Geometric Dimensioning and Tolerancing” and the “Dimensioning and Tolerancing Handbook” By: Drake, P., Jr., 1999 McGraw-Hill . The following is quoted from the “Dimensioning and Tolerancing Handbook” and explains advantages/disadvantages, accuracy and discrimination.
18.2 Advantages and Disadvantages to Paper Gaging
Since the optimum means for a geometric tolerancing requirement is through the use of a fixed-limit gage, the primary advantage provided by paper gaging lies in its ability to verify tolerance limits similar to those of a hard gage. Paper gaging techniques graphically represent the functional acceptance boundaries for the feature, without the high costs of design, manufacture, maintenance, and storage required for a fixed limit gage. Additionally, paper gaging does not require that any portion of the product tolerance be sacrificed for gage tolerance or wear allowance.
Paper gaging is also extremely useful in capturing dynamic tolerances found in datum features subject to size variation or feature-to-feature relationships within a pattern of holes. Neither of these can be effectively captured in a typical layout inspection. The ability to manipulate the polar coordinate overlay used in the paper gage technique gives the inspector a way to duplicate these unique tolerance effects. Since it provides a visual record of the actual produced features, paper gaging can be an extremely effective tool for evaluating process trends and identifying problems. Unlike a hard gage, which simply verifies GO/NO-GO attributes of the workpiece, the paper gage can provide the operator with a clear illustration of production problems and the precise adjustment necessary to bring the process back into control. Factors such as tooling wear and misalignment can readily be detected during production through periodic paper gaging of verified parts. Additionally, paper gages can be easily stored using minimal, lowcost space.
The primary drawback to paper gage method of verification is that it is much more labor-intensive
than use of a fixed-limit gage. Paper gaging requires a skilled inspector to extract actual measurements from the workpiece, then translate this data to the paper gage. For this reason, paper gaging is usually considered only when the quantity of parts to be verified is small, or when parts are to be verified only as a random sampling.
18.3 Discrimination Provided By a Paper Gage
With paper gaging, the coordinate grid and polar overlay are developed proportionately relative to one another and do not necessarily represent a specific measured value. Because they are generic in nature, the technique may be used with virtually any measurement discrimination. The spacing between the lines of the coordinate grid may represent .1 inch for verification of one part, and .0001 inch for another. A typical inspection shop may only need to develop and maintain three or four paper gage masters. Each master set would represent a maximum tolerance range capability for that particular paper gage. The difference between them would be the number of grid lines per inch used for the coordinate grid. More grid lines per inch on the coordinate grid allow a wider range of tolerance to be effectively verified by the paper gage. However, an increase in the range of the paper gage lowers the overall accuracy of the plotted data. The inspector should always select an appropriate grid spacing that best represents the range of tolerance being verified.
18.4 Paper Gage Accuracy
A certain amount of error is inherent in any measurement method, and paper gages are no exception. The overall accuracy of a paper gage may be affected by factors such as error in the layout of the lines that make up the graphs, coefficient of expansion of the material used for the graphs or overlays, and the reliability of the inspection data. Most papers tend to expand with an increase in the humidity levels and, therefore, make a poor selection for grid layouts where fine precision is required. Where improved accuracy is required, Mylar is usually the material of choice since it remains relatively stable under normal changes in temperature and humidity.
By amplifying (enlarging) the grid scale, we can reduce the effects of layout error in the paper gage. Most grid layout methods will provide approximately a .010 inch error in the positioning of grid lines. From this, the apparent error provided by the grid as a result of the line positioning error of the layout may be calculated as follows:
Line Position Error/ Scale Factor = Apparent Layout Error
For example, if a 10 ´ 10 to-the-inch grid is selected, with each line of the grid representing .001, a scale factor of 100-to-1 is provided, resulting in an apparent layout error for the grid of .0001 inch. However, if a 5 ´ 5 to-the-inch grid is selected, with each line of the grid representing .001, a scale factor of 200-to-1 is provided, resulting in an apparent layout error for the grid of only .00005 inch.
18.5 Plotting Paper Gage Data Points
It is extremely important for all users to plot data points on the coordinate grid of a paper “
