SAM135,
Measuring surface roughness measurements of very smooth surfaces is difficult. In order to get accurate results for surface finishes below 10 micro inches or 0.25 microns the stylus tip has to be in nearly brand new condition. If the stylus is slightly worn the profilometer measurements will underestimate the roughness of very smooth surfaces.
Many years ago I requested a deviation approval on behalf of a prototype supplier for the surface roughness of centerless ground pinion shafts. They measured 8 micro inches where 6 was required in the specification. The product engineer refused the SREA but allowed the supplier to polish to achieve the specified finish. I asked if current production shafts were polished and he said no. He stated that the production supplier was able to achieve the specified finish via grind processing only. He claimed he had data that confirmed that function deteriorated when initial finish exceeded 8.
As it happened I reviewed prototypes ordered from the production supplier not more than week later and armed with my brand new little Taylor Hobson portable Surftronic analyzer I discovered that regular production measuring 6 micro inches on the production profilometers actually measured 10 on mine. Needless to say my ah-ha caused a ruckus. We went to their lab to find calibration test blocks to settle the difference. While there I noticed a very high-end proficorder, they claimed was seldom used and that no one present had ever operated it. I assured them that I was familiar with it, we set it up, measured, and corroborated the 10 micro inch findings. All three devices including the production instrument with the worn stylus checked OK for value and linearity on the calibration test blocks.
The test blocks that come with the equipment that are used to calibrate gain and linearity have a lower value that is insensitive to slight stylus wear (I think approximately 25 micro inches) and an upper value sufficiently greater to set linearity without exceeding typically measured finishes (I think approximately 100 micro inches). There is standard that you can buy to check the condition of the stylus (I think approximately 10 micro inches) but to distinguish a 5 from a 7 the stylus has to be nearly new.
Paul
