K
Kenneth Czar
Hi all,
Which will be the best recommended for Megohmmeter instrument,analog type or digital type?Our customer is using analog type(prostat PRS-800)ours is ACL 800.
Our customer said that ACL 800 is not stable since it is supplied by 9 volts battery and it needs to stabilize first at 100 volts before it shows the reading ,while their analog type once you pressed the button it will give a reading within seconds.
Does ESD organization specify an analog or digital megohmmeter?
Note: both our instrument are calibrated and traceable with international or national measurement std.
We correlate out testing procedure and we obtain a reading within required specification.(1 x10 e 6 up 1 x10 e9)STM 2.1 ESD Std.
any positive info.....
thanks, :
thanks, :
