Minimum US FDA Labeling Requirements for a Class II Medical Device
Silvertabb
Assume there is a class II device containing the following components:
(1) battery door
(2) antenna
(3) standard screws use to fasten the antenna to the device
If customers call in and say that the device they received is either missing the battery dooror the antenna was broken, the company wants to have separate SKUs for warranty replacement.
For the US Market, what is the minimum labeling requirements the company must compy with? When responding, it would be great if you provide a regulation number, guidance name, or other source.
thanks
Ronen E
Problem Solver
Moderator
Re: Minimum US FDA Labeling Requirements
(1) battery door
(2) antenna
thanks
Hi, you might want to take a look here:
http://www.fda.gov/MedicalDevices/D...ce/Overview/DeviceLabeling/default.htm#link_2
The Specialist
There is nothing to stop you from having unique identifiers for each of the components you list.
Of course, the component does not have to be 'marked' with the SKU. This can just be a paper excersise (e.g. spare parts list in manual/tech document).
I can't quite see where FDA labelling requirements come in? Am I missing something?
J0anne
Joanne
I can't see where labelling comes into this either.
Maybe we are missing something?
