we recently had a audit and the auditors pointed out that all our sop's should have a revision date.
is this required ?
they stated that there should be a periodic revision of sop's and the next date should for revision should be on the sop ...
is this required ?
You should tell the auditor to go back for a correct training.Thanks for your reply we have everything as shown in your example but the auditor states that we should also have "next revision date"
we can only put a date after we revise.
but he insists that we should revise the document on a specific date even if there are no changes
thanks to all for these responsesThere has to be a periodic Management review of the Management System, including controlled documents such as the Standard Operating Procedures (SOPs). Controlled documents are typically controlled by means of a "Revision Number", or a "Revision Date", or both.
Example: SOP-0001 Internal Audit, Revision: 4, Revised: July 4, 2009
ISO 9000 requires:
5.6 Management ReviewThe evidence that the review of the Management System (and its documentation) is usually demonstrated through the revision number and/or revision date (as well as in the records of the minutes of Management Review). Even if no changes are ever required, the revision number/date should appear on SOPs, and all controlled documents, and evidence of review must be maintained.
5.6.1 General
Top management shall review the organization's quality management system, at planned intervals, to ensure its continuing suitability, adequacy and effectiveness.
This review shall include assessing opportunities for improvement and the need for changes to the quality management system, including the quality policy and quality objectives.
Patricia Ravanello
is this required ?
I am going to disagree with a lot of what is being said here. I don't know of any requirements to review your documents. I know of no requirement stating that you have to have an expiration date, or a next revision date. I am not opposed to having documents with expiration dates, but we need to separate what is required from what is useful.
The closest to a requirement I can find is "b) to review and update as necessary..." [4.2.3]. The key words here are "as necessary". If a process changes, then you need to review the documentation to see how the change affects the document. This is not a requirement from the standard, but a necessity related thing.
If your auditor is telling you, you need a "next revision due" date, one of two things are in play. 1) the auditor is putting requirements where there are none, or 2) the auditor is seeing something in your system that indicates you may have process changes that are not reflected in your documentation, and the auditor feels you are not reviewing the documents in a necessary fashion.
