Re: What is the difference between the Material and the Performance Results in the PP
We are supplying a module: bracket with some metal parts.
The drawing of our costumer req. the salt spray for the module ("to be tested in the assemled"...etc.). But our internal single part drawing states also the req. for the single part, to be testet in the whole module.
The only problem we have here, where should we put, for example this king of req.: in the material or performance report ?
I am sure, the OEM will not make any problem, when we just put this under the performance, but it is just for better understanding.
Greetings from sunny Poland and thanks in advance
In general, salt spray is considered a performance test. It's usually a coating (plating, paint, etc.) that's being tested for corrosion resistance, and the question is: How well does the coating
perform under certain controlled conditions? On the other hand, the component (the piece-part) being tested has material specifications that tell what it's to be made from, such as a specific type of metal, ususally with reference to a published standard. The distinction is really pretty simple; in general
material tests are for raw materials, and
performance tests are for parts or assemblies that have been manufactured (but not necessarily in end-use condition), where there are specific requirements for proving that design intent has been satisfied.
Keep in mind that you're not bound to the forms in the PPAP manual. You can use any form you want; the manual itself gives the minimum requirements for content of both kinds of test reports.
