Re: Cfg-1003,cfg-1004,cfg-1005
Please be patient. There is some debate as to which form is to be used and when. Does any one have a simple, and I mean simple explanation as when to use each form?
None of the forms (found in the AIAG PPAP manual, 4th Edition) are mandatory.
CFG-1003 is for PPAP dimensional reports.
CFG-1004 is for material test results.
CFG-1005 is for performance test results.
The first is self-explanatory (I hope).
Material test results are test results for (e.g.) raw materials, and other design record material specifications. Often a supplier's cert is substituted for the form, although they usually don't meet all of the requirements specified in the PPAP manual. If a customer requires use of the form, sometimes the information from the supplier's certs/test results are transferred to the form, and the supplier cert is kept but not submitted.
CFG-1005 is for performance test results. Performance tests are for things such as corrosion resistance, impact resistance, flammability, environmental exposure, etc.
