aliasJohnQ
How do I set up a PPM with Total pcs shipped vs. Total Scrap for the month?
What is a good number and bad number?
Thank!!!!
Thank!!!!
I would think that you would want to know how many pieces are scrapped in proportion to how many are made, not how many are shipped. The standard formula is:How do I set up a PPM with Total pcs shipped vs. Total Scrap for the month?
What constitutes an acceptable PPM level depends on what customers expect and what your process is capable of. In general, there's no good reason to use PPM unless your customers require it or you're actually making a million of something.What is a good number and bad number?
Thank!!!!
How is saying your PPM is 10,000 better than just saying you have a 1% defect rate?Why isn't it a good idea to use ppm if your using less than a million parts of something???
This is an apples/oranges comparison. In order for it to make sense, you need to use the same unit of measure for both quantities. In this case, you would need to know either the dollar value of the 780,000 pieces, or how many pieces are represented by the $950.What will the ppm number be if you have $950.00 of scrap but your total is: 780,000 pcs made. This is not all one part, but many.
Ok, I know how many are represented by $950.00. Then what?
How about scrap ($) as a percentage of sales?What are the low cost ways to measure scrap vs. product out the door compared to PPM's?
