Internal Audit of the Training System - Corrective Action Necessary?
N
NoSleep
I am in the middle of an internal audit of the training system. The training system is fairly basic; we outline in our SOP's what we are going to do for training and we do it. HOWEVER I have decided to take this audit in a deeper direction and cross reference internal (not customer reported) NCR's to a possible gap within the training system. I do believe I have found that our training system is lacking in content and while we do what we say we will do I don't think what we do is extensive enough. So does this fall into a Corrective Action Report area or does it fall under something else?
Thanks in advance:thanx:
Mikishots
Re: Corrective Action Necessary? OR what is the best approach??
In many companies, nonconformance reports are generated for each nonconformance (obviously). They are then typically compiled on a set schedule by quality engineers whose job it is to analyze and trend them. If they find that similar workmanship errors are present (or any other trend is seen), they can generate a corrective action to address the identified issue.
This method of collecting and trending has the advantage of not permitting "knee-jerk" reactions to one-off problems. So often, an incident is seen as a blaring red light identifying a problem, when it may be nothing more than a coincidence or a single, isolated event.
N
NoSleep
We do write up each non conformance individually and address them individually my question was more in regard to a number of NCR's that were written up for the same basic non conformance indicating a gap within our training system. So does that gap in the training get it's own Corrective Action or just a suggestion for continual improvement
qusys
Probably I am missing some piece. If you are perfoming an internal audit and your criteria are related to assess the compliance to your internal SOP, you shall write a non conformance with the evidence in your internal audit report. Based upon this, a CAR should be submitted following the internal audit activity.
I do not understand what you mean for "training system". Is it a tool? ISO 9001 does not require it but only the items of 6.1 and 6.2.
RoxaneB
Change Agent and Data Storyteller
It sounds as if you are attempting to show the correlation between the responses/actions taken on an issued CAR within your system to your existing training system. This is neither a review of the CAR process or the training process, but a proactive way to show that if CAR after CAR cites re-training, then perhaps the training system is not robust enough.
Is this a correct interpretation on my part?
If so, I applaud the effort and would put under the heading of an "Opportunity for Improvement" as you are attempting to strengthen the training process and your organization's documentation, by the sounds of it.
N
NoSleep
You are correct although within our system not every Nonconformance requires a CAR; technically though I am looking to see if our employee training system is not robust enough and that would be why we are seeing recurrence of NCR's a member of management here suggested that I should write a CAR against our personnel training system as a whole but I was thinking it would fall under the category of "Opportunity for Improvement" :thanks: for your help!!!!
P
PaulJSmith
I agree with the notion that you have what appears to be an "Opportunity for Improvement" more than an opportunity to write yet another CAR. However, you should handle it in a manner consistent with your company's policy.
And just to throw this out there ...
If you have multiple CARs which point to "training" as the root cause and/or Corrective Action of Nonconformances, you may also have an "Opportunity for Improvement" in your CAPA process.
Something to consider ...
N
NoSleep
Thank you for your input I will look into that system as well and see if we can improve on it also. I have only been in this position with this company for a little over a year and the first year was truly a lot of putting out fires so I feel like I am just now getting the opportunity to help uncover areas that could be improved upon. Thank you again
You're walking around with a heavy solid object, trying to find a container that it will fit in. Think of the improvement process as being liquid and taking the shape of whatever container is used. It's the thing contained that's important, not the container. There is a perceived opportunity to make something better, so instead of trying to determine what to call it, just do it. Paul makes the good observation that you need to handle this in consonance with company policy, but you also need to look at the policy and make sure it allows enough leeway to be able to avoid wasting time on nomenclature.
somashekar
When you believed that your training system is lacking in content, I am sure you realized and believed it before being in the middle of an internal audit system. So when you begin to dig deeper into what you believed in an internal audit, you are more into fault finding, which is not the spirit and purpose of the internal audit process.
So when you complete your internal audit objectively and look for both positives and improvement areas, address your good intentions directly as a continual improvement process of the training system. During your next internal audit, get the training process audited by someone else to check on how effective your steps taken have yielded results. :agree:
