Dscalf1
Hey I have written a macro that automatically pulls a query from access into excel now I am trying to make it where the user does not have to enter the SQL Server user ID and password every time they open the excel sheet because a lot of the users do not know the password.. I have copied my vba code below and any help would be greatly appreciated: (The bolded part is what is not working)
Sub BreadLinePerShift()
ActiveSheet.Range("L1") = Format(Now(), "mm/dd/yyyy hh:nn")
'Step 1: Declare your variables
Dim MyDatabase As DAO.Database
Dim MyQueryDef As DAO.QueryDef
Dim MyRecordset As DAO.Recordset
Dim i As Integer
'Step 2: Identify the database and query
Set MyDatabase = DBEngine.OpenDatabase _
("\\bburockfsxxpp01\public\New Production Folder\WinSPC3.accdb")
Set MyQueryDef = MyDatabase.QueryDefs("Bread Line Per")
'Step 3repare the connection string
cnn.Open _
ConnectionString:="Provider=SQLOLEDB.1;" & _
"Data Source=BBUROCKWSP" & strServerName & ";Initial Catalog=winsp" & strDatabaseName & _
";User Id=wins" & strSQLUsername & ";Password=bbu.win" & strSQLPassword
'Step 4: Define the Parameters
With MyQueryDef
.Parameters("[Start Date]") = Range("B1").Value
.Parameters("[End Date]") = Range("B2").Value
End With
'Step 5: Open the query
Set MyRecordset = MyQueryDef.OpenRecordset
'Step 6: Clear previous contents
ActiveSheet.Range("A5:E10000").ClearContents
'Step 7: Copy the recordset to Excel
ActiveSheet.Range("A6").CopyFromRecordset MyRecordset
'Step 8: Add column heading names to the spreadsheet
For i = 1 To MyRecordset.Fields.Count
ActiveSheet.Cells(5, i).Value = MyRecordset.Fields(i - 1).Name
'Step 9: Sort the data in column
Range("A5:E60").Sort _
Key1:=Range("B5"), Header:=xlYes
'Step 10: Refresh entire workbook
ActiveWorkbook.RefreshAll
Next i
End Sub
Dim i As Integer
cnn.Open _
With MyQueryDef
End With
Next i
End Sub
