markro
I've attached a print for a part we are machining. I'd like to make an attribute gage to check true positioning on the shop floor. If a plate was created with pins in the positions described with the basic dimensions on the print and with the positions verified, could I make the pins the smallest diameter/smallest minor diameter of each of the 11mm holes/threaded hole and the ?54.4 hole since each true position callout uses maximum material condition?
