Re: Revision Control of PCBs (Printed Circuit Board) and Printed Circuit Board Assemb
I have not seen an industry standard for naming or numbering conventions of PCBs.
I have worked in contract manufacturing for a long time and has been exposed to all kinds of numbering system. Every customer had their preference. We had to convert them to our system to reduce confusion. Rev up does not necessarily mean obsolescence of the older one. The revs have to match the PD.
The numbering system should suit your organization. For example, if you have too many Gerber file changes, you might select one way and if yo have lead time issues and have to buy cross, you might select another way.
The easiest one I dealt with was "x.a" format, where x= the rev level of Gerber and a=the rev level of BOM/schematic. If the customer dictates the process, you might want to make it "x.a.b", where b corresponds to the qualified process. We would ask the board house to print the PCB rev and add a silk screen rectangle for handwriting the ".a.b" with a sharpie.
hope this helps!
