Anerol C
Hi to All,
I need how you are assuring quality on your machining operations.
We have a machine shop center where we run about 600 different parts monthly, currently parts are inspected by quality auditor randomly based on lessons learned or critical parts, if parts are ok a realease sheet is put on the parts, but the realease sheet is just for those critical parts or parts that based on experience need to be checked, for the rest of the parts everybody knows that those parts are ready to go when the job is finished.
We are working to implement audit check list for the operators where they will verify machine set up and product features; the audit check list will be completed for the operator for all part #'s that will be run at the shop, as the auditor doesn't have the capacity to inspect all parts: we will divide the parts in Critical parts and not critical parts, on the critical parts auditor will inspect/measure the critical features per audit check list, if part is ok auditor will stamp the work order and put the release sheet, for the non critical parts auditor just will verify that operator has completed the audit check list and parts is ok and will stamp work order. What do you think about this?
Is anybody using a sampling plan for inspectio at your machining shops?
I appreciate your comments.
AnerolC.
AnerolC.
