If as you said, I will be very surprised.
All of our products have higher leakage current after humidity treatment (about 10% higher than the values in cold condition). But I can not find any hygroscopic insulation has been employed in our equipments. Did the CB test lab tell a lie and issue a wrong CB report? BTW, our company has been established nearly 15 years, I am working for the R&D department.
In fact, the capacitors have positive or negative temperature coefficient, it depends. Anyway, the humidity treatment test almost has nothing to do with the temperature (since ambient temperture is OK). Therefore, we talk about the temperature coefficient of components seem to be meaningless in humidity treatment test. Moisture is the major concern, rather than the temperature.
I agree with the point of insulation resistance of capacitor. Actually, I did not mean the insulation resistance would greatly influence the leakage current. The insulation resistance shall be not less than 100 MΩ according to IEC 60384 series. The contribution to the leakage current shall be microampere level. Again, the low temperature in humidity chamber would not affect the insulation resistance of capacitor.
I also agree that the condensation shall be avoided (this is also the requirement of the standard). But, more or less of water film is expected (In real world, it also shall be. We also did many in-house tests and found this phenomenon). I also did not mean that the water film will form a direct conducting channel and cause the insulation breakdown (I had rather thought, this would influence the
distributed capacitance).
Actually, most modern equipments would not fail after the humidity treatment test. But, the leakage current indeed increase after the test. This contrary to your point of view. I think the practice is the criterion of truth.
If anything is wrong, please correct me.
