How do you decide what is a Process, a Procedure or Work Instruction?
P
plastic
How do you decide what is a process, procedure or work instruction? I am in charge of moving my company from QS 9000 to TS 16949 and I am having trouble knowing where to start, as far as the Manual (can that be just a restatement of the standard with my organization's name in it), Procedures (I know there are 7 required), Processes and Work Instructions. I am feeling the pressure and would appreciate all the help I can get. Also, can I use most of our QS procedures since I feel they still apply.
Thanks,
P
Jrich
Re: Procedure, Process, or Work Instruction????
Here is what I know and what we did:
Use you QS Procedures as much as possible. Update them to cover any changes in TS. Basically for us they are a re-itteration of the TS spec with a little detail on how.
Processes - You need to define these for your organization. I believe there are 10 recommended (Market Analysis, Bid Tender, Order Request, Process/Product Verification and Validation, Manufacturing Provisions, Product/Process Design, Delivery, Payment, Post Sales Customer Feedback, and Warranty). There are Six Characteristics to each (Owner, Inputs, Defined Process - ususally a process flow, Outputs, Links, and Measurables).
Work Instructions are where you provide the detail of how things get done. Use your QS ones and Update as required.
You should do a Gap Analysis to see what you are missing.
Good Luck.
Jason:confused:
Thanks,
P
Welcome to the Cove, Plastic. :bigwave:
Depending on what you're referring to, "procedure" can refer to a document or it can be synonymous with "process." The standard refers to "documented procedures," which means "documented processes." You must, for example, have processes for preventive and corrective action, and those processes must be documented. You might call the document a procedure, or a work instruction, or some name you invent yourself. It doesn't matter, so long as there's a process and the process is documented.
F
fireonce
Good Luck.
Jason:confused:
You are very professional!:bigwave:
F
fuzzy
Re: How do you decide what is a process, procedure or work instruction?
Thanks,
P
Welcome to the Cove, Plastic! Just wanted to comment on your question regarding the Quality Manual. For the record, under both ISO and TS the manual is not,:mad: repeat NOT, a word for word restatement of the standard. Those days are gone. Thank you Lord:D . Please do a search in first the TS and then ISO forums on "Quality manual" and I know you will aquire information on the freedom you will have in constructing your unique ;) Quality Manual. Good luck!:applause:
Jen Kirley
Quality and Auditing Expert
Good advice so far.
In doing a search you may find a list of threads that will contain a lot of information.
Look through the titles and first seek out the threads that seem to best apply, like this one. Work Instructions - What are the Requirements for Work Instructions?
Documentation is a big subject so I encourage you to take your time in learning it.
Antonio Vieira
Involved - Posts
For defining what's processes I use Michael Porter's approach of "Value chain".
Of course we can write procedures or work instructions to manage these processes...
For other subjects that are out of this "value chain", but are still organization activities, I use to right specifications or procedures, but don't consider them as processes.
H
hmisra
Thanks,
P
Sir,
In my view we define process as a name of an activity e.g purchasing, delivery, enquiry handling etc. WE can say purchasing as a process and can define its six element i.e input, output, competence, infrastructure, methods, required to run this process and lastly the performance indicators of the process i.e to judge whether your process is running efficiently.
Procedure is what we can define the methods how the purchasing activity is being carried out in the organization. And work instructions is again more or less same as procedures which define how the activity is to be carried out.
Thanks,
G
Gary E MacLean
I know I am a bit late but since I have just read all the other posts and I haven't yet seen what I might consider the best answer I have to throw my two cents in - for whatever it is worth.
Define yourself a six tier system. Yes, six, not four;
LEVEL ONE: Quality Manual (Top Management's committment to follow ISO)
LEVEL TWO: Administrative Procedures (document your selected processes)
LEVEL THREE: Work Instructions (document sub-processes directly related to your processes, or level twos.
LEVEL FOUR:Job Instructions (A very important level. These belong to your organization. They explain expressly how you set this part up, how you package this one, how to run this piece of equipment and so on. They are site-specific. You need them but lets not mix them up with the system related documents. You should never have to change these simply because the standard gets updated. You will only revise them if your operation changes. These really don't even have to be audited - just their existence.
LEVEL FIVE: Blank forms and reference documents (Things like any blank forms that will become a record, SPC ConstantS table, rockwell conversion chart, viscosity table, things that you may want to issue from your own machine but things that are full of unchangeable fact.
LEVEL SIX: Records. (These are simply evidence that somethng has happened.
And yes, the Quality Manual is nearly a re-hash of the standard unless of course you plan on doing something that is not in the standard or you plan on not doing somethIng the standard requires you to do. If you are going to acknowledge the standard and agree with it why not just say so in your top level, committment document. Typically there is very little direction or instruction within the qualty manual anyway; it is usually policy.
There is no set list of processes. In fact the recommended list varies from registrar to registrar (who incidentally truly have nothing to do with what you call your processes anyway - it really is none of their business how you satisfy the standard as long as you make it work) Just look at what you do and name your prmary processes.
There are PROCESS recommendations galore but I would highly recommend resisting calling anything having to do with anything not defined within the standards; costing, profit margins, accounting, personnel benefits, market analysis, bench marking, safety, payment and so on, a process. There are no published criteria within ISO9001:2000 for any of these so there is nothing for you to stake a claim on and nothing for your registrar to reference when they decide to write a NC. They will be auditing these or any other activities that are not defined within the standard to their best judgement and desires, not healthy for you and not healthy for any audit program.
OK, more perhaps somewhat useable advice for you. We seem to all have a good supply of that.
Good Luck
The commitment you refer to is generally captured in the quality policy; the QM should be more than that.
No issues here; this is pretty much standard.
Why two tiers here? What's the difference between three and four? They don't have to be audited?? How to you do part/process audits if you don't verify that the work instructions are being followed? I'd like to learn more about your rationale for the bifurcation.
I understand the need to control forms (usually tier 4 in a 4-tier system), but I don't see a need for controlling "unchangeable fact." If it's immutable, why does it need to be controlled?
Again, no issues; pretty much standard.
Quality manuals that are "nearly a re-hash of the standard" are mostly worthless beyond the requirement to have a quality manual; why have a potentially significant document that serves no useful purpose? Most quality manuals are useless because they came into being as a result of desire to fulfill what's seen as a bothersome requirement. If the goal is simply compliance with the standard, a rehash QM will certainly fill the bill, but shouldn't we be aiming a little higher than that?
This isn't about giving things names, like newborn children or puppies; the object should be to identify significant processes, optimize them and document the proven methods. Again, it's about making things work as well as possible, not worrying about what might be audited or what name you give to something.
What you call a process doesn't change the fact that it is a process, and if a process is perceived as being worthy of control and documentation, it should be controlled and documented. If you do it well (and that's the primary objective, I hope) then you don't have to worry about auditors. The primary function of auditors (internal or external) is to confirm the auditee's contention that the system is working as designed, not to play "gotcha!". If an auditor (internal or external) is clearly on a search-and-destroy mission, then someone needs to step in and take control, and not allow auditors with fanciful imaginations to make stuff up.
As we discussed in another thread, the standard mandates the existence of certain processes and documents, and beyond that whatever is necessary for the functioning of the system. The idea of a tightly-structured hierarchical document system is a bit old hat, and cleaving to the idea that it's necessary has a tendency to stifle creativity. The best quality systems I've seen are the ones where someone has set out to build an efficacious system, one in which the satisfaction of ISO requirements is a secondary consideration. We all know that it's eminently possible to cookie-cutter your way to registration, but if you set out with banality and needless rigor aforethought, you'll wind up with a system that's banal and needlessly rigorous.
