bgtom
hi everyone,
first of all, i know i do not post enough on here but everyones input is always valued and researched often, and i direct many people to this site. i have developed and implemented many systems over the years and have never had a problem. my problem now revolves around "process validation". it is a special process, "passivate". the company having the problem is certified to 9001:2008 but was audited the first time to ISO 13485 by their customer and got hit on process validation. the company happens to also be a vendor of mine so i went down to help them out and i put in place some simple tools to help in the validation of their processes. i used simple tools such as flow charts, capturing data throughout the processes, (temps, concentrations, times, etc,) using the basic thinking that if you monitor and maintain the same indicators each time you will achieve the same desired results everytime. of course i understand the rule that through data analysis, you have to "prove" that the data you are tracking is valid and pertinent and contributes to the final results but the only way to do this is by gathering the data and the final results (statistical analysis) and thus validating the process. this takes time and data needs collected to make sure you are collecting the proper data to achieve those results.
the auditor came in today again and disputed the data we are collecting and called our process "elementary". yes, it is elementary, meaning that it is the beginning of a longer and more detailed process. but, i do believe and i have proven over the years it to be an effective method of process validation. i have rambled on forever now being i am very frustrated, but i guess my question would be, do you view process validation the same as me, do you view it as a system in which it is up to you to create, so that you can achieve the same DESIRED results at the end everytime? to me that is the goal, if the product comes out the same by following the same procedure and achieving the same indicators everytime then you have met your goal. i have used this method to meet ISO 9001, ISO 13485 CFR820, GHTF, and others through the years but now all of a sudden, this young buck is telling me i am all wet, and that validation falls under the same requirements of sterilization. i am stunned. thanks in advance and sorry for the rambling, this is why i don't post much.
