F
fonk140
Hello I have some questions concerning the IEC 60601-1 standard, I would be very grateful if you could clarify me these points:
- In our device 3 wires go from the power ac inlet to the power supply, how 2 MOOP are achieved between the two phases?, and between each phase and protective earth?. It is enough with the normal insulation of the wires or something more is required?, creepage and clearance distance apply in this case?. Does the fastening of the wires need special protection?
- Are creepage and clearance distances required in secondary circuits with voltages below 15 V?
-Does plastic enclosure counts as 1 MOOP or as 2 MOOP?
- Can/Should secondary circuits and SIP/SOP circuits be earthed to protective earth?
Thanks in advance!
Thanks in advance!
