argon - 2006
Help.
Has anyone performed MSA on Contact angle measurement? COuld you advise me how?
We use this method to measure surface adhesion. A drop of water is applied on the surface being tested and the angle formed from that surface to the tangent line on the droplet is measured and is the basis of the adhesion value. Problem is, the application of the droplet is subjective since it is done manually. I'm trying to figure out how to simulate the process (if that is the right move, since its a destructive test) so that i can do MSA. But i'm not certain what's applicable: attribute or variable msa?
