SimpleIsGood
My company makes coolers--radiators. We test for cleanliness using the SAE J1726, the Charge Air Cooler Internal Cleanliness, Leakage and Nomenclature standard.
However, one of our customers wants us to meet the SAE J1227, the standard for Assessing Cleanliness of Hydraulic Power Components and Systems.
We are actually okay in terms of the total weight or amount of dirt. The problem is trying to meet the largest particle size standard. J1726 (the one we like) allows particles as large as about 3mm. The J1227 standard (the one they likes) only allows particles as large as .3mm.
THAT'S 10 TIMES SMALLER!
I believe they are applying a standard meant for things like hydraulic actuators, pistons and gas cylinders. They should be using the one intended for radiators. Anyone know if I'm correct? Any suggestions on tactfully "esplaining" to them that the standards are not compatible? That we shouldn't be asked to meet the tougher power component standard? At least not without a cost increase?
Thanks.
Thanks.
