E
ed1978
I am fairly new using Minitab and I need to run some analysis using it.
I have 2 technicians who will be cycling a rubber dumbell 3 times from 0 to 10% elongation and they will repoprt the mean of the three cycles. Each technician will test 15 rubber dumbells. I will then have 15 mean values of tensile data from each operator. I need to find out if there are variances, interaction, etc.
I thought I could use Gage R&R nested, since the test can not be done twice on the same sample (since the rubber sample will relax too much). I also thought I could use Anova instead.
Can someone guide me? Is there another method to use?
I would like to know if there are variances in test, machine, part to part, technicians, etc.
Thank you greatly in advance!!
