R. Webb
I am not a chemist so can anyone help. I received the following question from my supervisor. It would be on a cold rolled sheet metal part. Packing would be wrapped in foam in a dowble walled cardboard box.
"Dick,
Can you see if this zinc plating spec we use for XXXXXX is sufficient to prevent corrosion on parts going by boat to China?
Thanks,
XXXX"
THe plating spec is,
" ASTM B633, .0002 in. min., Type II Passivation; 96 HR Salt Spray Minimum and 5 Milliohms per square inch electrical resistance maximum. Color shall be clear to irridescent. All surfaces significang. Trivalent chromium based bath chemistries shall be used."
Will the parts get to China okay?
"Dick,
Thanks,
XXXX"
