The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Medical Devices, Medical Information Technology, Medical Software and Health Informatics > Medical Device Related Standards > IEC 60601 - Medical Electrical Equipment Safety Standards Series
Elsmar Cove Forum Sidebar
Custom Search
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Atul's
Symphony Technologies
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
iec 60950 (information technology equipment - safety), medical device electronics and electrical equipment, mopp (means of patient protection), usb port isolation
  #1
Old 22nd June 2012, 01:08 AM
Roland chung Roland chung is offline
Appreciated Information Resource
Registration Date: Feb 2011
Thanks Given to Others: 82
Karma Power: 44
Roland chung is appreciated, and has over 100 Karma points.Roland chung is appreciated, and has over 100 Karma points.
Please Help! Separation of Network Port from other Circuits including Patient Circuit
Hello Coves,
We have a medical device employs network port which is intended to be used for communication.
According to IEC 60950, the network circuit in the equipment is called TNV circuit. And the working voltage for TNV-2 or -3 circuit is 120 Vdc.
So, the barrier between TNV circuit and SELV circuits (e.g. RS232, USB port) should be 2 MOOP @120 Vdc, and patient circuit should be 2 MOPP @120Vdc.
Is it too stringent for the separations?
Thanks,
Roland
  #2
Old 26th June 2012, 04:00 AM
Stijloor's Avatar
Stijloor Stijloor is offline
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 2,950
Karma Power: 1431
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Re: Separation of Network Port from other Circuits including Patient Circuit
A Quick Bump!
Can someone help Roland?
Thank you very much!!
  #3
Old 30th June 2012, 08:05 PM
Peter Selvey Peter Selvey is offline
Registration Date: Oct 2009
Thanks Given to Others: 35
Karma Power: 86
Peter Selvey is appreciated, and has over 1700 Karma points.
Peter Selvey is appreciated, and has over 1700 Karma points.Peter Selvey is appreciated, and has over 1700 Karma points.Peter Selvey is appreciated, and has over 1700 Karma points.Peter Selvey is appreciated, and has over 1700 Karma points.Peter Selvey is appreciated, and has over 1700 Karma points.Peter Selvey is appreciated, and has over 1700 Karma points.Peter Selvey is appreciated, and has over 1700 Karma points.Peter Selvey is appreciated, and has over 1700 Karma points.Peter Selvey is appreciated, and has over 1700 Karma points.Peter Selvey is appreciated, and has over 1700 Karma points.Peter Selvey is appreciated, and has over 1700 Karma points.
Handling of TNV is missing point in IEC 60601-1.
For MOOP it seems best to just apply the TNV requirements and limits from IEC 60950-1, as it is a special area and needs to consider things like surges (transients), ringing and so on not covered by simply using the nominal working voltage.
For MOPP, if the equipment is Type BF or CF, it seems reasonable to assume the additional F-Type barrier (typically 1.5kV/4mm) together with the TNV isolation is sufficient to provide 2 MOPP in total between the TNV circuit and the patient.
If the equipment is Type B, it might be best to consider on a case by case basis, depending on the type of contact the patient has with the equipment (e.g. transient, constant, plastic, metal, wet, dry etc).
Thanks to Peter Selvey for your informative Post and/or Attachment!
Smilies are On
Connection of Secondary Circuits to Medical Weight Scale Enclosure itzbobz IEC 60601 - Medical Electrical Equipment Safety Standards Series 2 31st October 2011 12:58 AM
Patient Circuits / Patient Connection / Applied Parts - Medical Device Definitions william_N IEC 60601 - Medical Electrical Equipment Safety Standards Series 3 27th September 2011 10:22 PM
Revision Control of PCBs (Printed Circuit Board) and Printed Circuit Board Assemblies Bunny Manufacturing and Related Processes 3 11th November 2010 05:57 PM
Short-circuit in electronic circuit - FMEA failure effect or a failure cause? Jim123 FMEA and Control Plans 7 10th May 2007 09:10 AM
Including multimeters and network testers as monitoring and measurement devices Ashley Cardin ISO 9000, ISO 9001, and ISO 9004 - Questions and Discussions 5 1st June 2006 03:43 PM
The time now is 01:27 PM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
