Re: HELP please - control of soldering irons
What are your requirements? What is required by your customers?
If there is no requirement - it is not a nonconformance.
No one likes situations where bad production can be "not a nonconformance".
Even if a customer's spec is no more than the word "solder" plus a task-implied minimum-functionality requirement (i.e. tinner copper wires reliably attached to tinner copper terminals with good resulting electrical conductivity), there are some technically implied specifications that must be intelligently met in order for production to be acceptable.
In hand soldering, whatever solder material is chosen for the job, it will have an upper and lower temperature bound during the heated phase to produce electrically and mechanically reliable joints. The joint must be held motionless during cooling. The ratio of flux to solder must be appropriate for the joint nature, i.e. how much solder it requires. The flux must be both appropriate for the work process and post-production operational enviornment, and appropriate for the surface conditions of the materials to be joined and the process's temperature profile.
The iron must have a thermal mass and/or surge energy capability that is appropriate (not too small, not too large) for the job to be done.
The amount of solder and geometry of the joint...even if not to qualified aerospace standards...must be reasonable, i.e. too little or too much, or too weird a geometry, gives rise to legitimate uncertainty as to reliability and quality.
Wave, pot or reflow soldering of course would have totally different specs, implied if not stated.
I'm sure a process expert could discuss this better... but I know from production experience that these requirements exist. If a customer sent us an MR coil electrical assembly job and failed to state one of the above specifications, we would not consider ourselves to be operating in a no-conformance-required zone in regard to that issue. If an auditor decides not to review our actions in regard to some requirement where the customer failed to give us an adequate spec and we filled in the blanks...so be it. We regularly do stuff with a lot of complex interactions between requirements, though, where the auditor has to review our conformance in regard to some customer-specified issue that is dependent on other issues where the customer's requirements are not as well defined. We don't seen it as productive to get into negotiations with auditors over what we were required to do. We'd rather just "do it right", get clean audits and move on to the next job.
