I thought you were referring to product BB testing and extended E monitoring as a substitute to cleaning validation. Of course I stand for the basic E and BB monitoring of the clean-room. I only meant to point out that with the lack of a proper cleaning validation much more frequent / extensive E & BB testing would be required for maintaining a similar confidence level.
Another, more general, comment: A "validation" is usually meant to provide confidence that given certain inputs, a process would consistently provide certain outputs, regardless of noise. As such, I would include in any cleaning validation extreme values of controlled parameters, and also test the sensitivity to noises (uncontrolled parameters), as much as practicable. If done properly, such validation could provide confidence of the cleanliness level even at the extremes that can be expected in the validated environment. Demonstrating effectiveness at nominal or optimal conditions is not a validation. It's a verification.
Cheers,
Ronen.
