The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection, Prints (Drawings), Testing, Sampling and Related Topics
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
aluminum alloy, heat treatment, rockwell hardness, aluminum (general topics)
Reply
Old 5th May 2011, 12:43 PM
R. Webb R. Webb is offline
Involved in Discussions
Registration Date: Jul 2009
Thanks Given to Others: 8
Karma Power: 20
R. Webb has less than 100 Karma points so far.
Please Help! A way to verify 7075 T0 Aluminum has been successfully Heat Treated to T6
I need a way to verify 7075 T0 Aluminum has been successfully heat treated to T6. The heat treater we use says they can verify the process but not the result. I found the thread here and just want to confirm that a Rockwell "B" of 47 to 60 confirms a T6 hardness in aluminum. I have not been able to find a cross reference for this and am not a metalurgist.
6061-T6 Aluminum - Any reason Heat Treat can't hit Minimum of RB/50?
Sponsored Links
Old 5th May 2011, 02:50 PM
sorin's Avatar
sorin sorin is offline
Appreciated Member
Registration Date: Oct 2002
Thanks Given to Others: 191
Karma Power: 98
sorin is appreciated, and has over 1300 Karma points.sorin is appreciated, and has over 1300 Karma points.sorin is appreciated, and has over 1300 Karma points.sorin is appreciated, and has over 1300 Karma points.sorin is appreciated, and has over 1300 Karma points.sorin is appreciated, and has over 1300 Karma points.sorin is appreciated, and has over 1300 Karma points.sorin is appreciated, and has over 1300 Karma points.sorin is appreciated, and has over 1300 Karma points.sorin is appreciated, and has over 1300 Karma points.
Re: A way to verify 7075 T0 Aluminum has been successfully Heat Treated to T6
What is the referenced standard for the material? What are your PO requirements? (example: HT 7075 T0 per ....etc.)
Science. It's not a democratic process.
Sponsored Links
Old 6th May 2011, 09:37 AM
Karma Power: 20
Thanks for responding. The specification is:
Heat Treat 7075-0 to 7075-T6 Per SAE-AMS-2770
Old 6th May 2011, 11:38 AM
sorin's Avatar
Appreciated Member
Karma Power: 98
In Reply to Parent Post by R. Webb View Post
AMS-2770 H
Para 4.3.1.3 Other Alloys or Other Tempers
Each lot of parts shall be hardness and conductivity tested. Testing shall be in accordance with 4.3.1.3.1 or 4.3.1.3.2
See those 2 paragraphs - specify on PO which one you want to apply (both request hardness testing).
Hardness results shall be as per AMS2658 (which I don't have).
Old 6th May 2011, 12:22 PM
andygr's Avatar
andygr andygr is offline
Registered Visitor
Registration Date: Mar 2006
Thanks Given to Others: 13
Karma Power: 74
andygr is appreciated, and has over 1500 Karma points.andygr is appreciated, and has over 1500 Karma points.andygr is appreciated, and has over 1500 Karma points.andygr is appreciated, and has over 1500 Karma points.andygr is appreciated, and has over 1500 Karma points.andygr is appreciated, and has over 1500 Karma points.andygr is appreciated, and has over 1500 Karma points.andygr is appreciated, and has over 1500 Karma points.andygr is appreciated, and has over 1500 Karma points.andygr is appreciated, and has over 1500 Karma points.andygr is appreciated, and has over 1500 Karma points.
For 7075 T0
Rc B 22 max
Conductivity 44-48
At 47-60 it looks like you are high on hardness for this temper
For the T6 temper the hardness is 84 max for the anneal condition and min for everthing else
Old 6th May 2011, 04:38 PM
Karma Power: 20
Matweb is telling me that the conversion from the Brinell Hardness Value is 87 Rockwell B form 7075 T6 Aluminum. I am not sure what 84 max for the annealed condition means.
What I really need is a book or website that goes over the basics and includes this information. Don't get me wrong as I really appreciate your help but I am a novice with this material and need to get up to speed on it, at least for the verification aspects of it.
Old 9th May 2011, 07:47 AM
sorin's Avatar
Appreciated Member
Karma Power: 98
In that case, go after this:
http://www.techstreet.com/standards/...oduct_id=54586
Thanks to sorin for your informative Post and/or Attachment!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Issue: Suppliers charge for complete Level III PPAP package - Heat Treated Parts vardar3 APQP and PPAP 16 15th December 2011 01:50 AM
Shipment made to Canada have to be on heat treated pallets or skids dbulak Other ISO and International Standards and European Regulations 7 7th October 2008 05:35 PM
Aluminum T6-T61 Heat Treating - What Info/Std Do I Need? Crusader Various Other Specifications, Standards, and related Requirements 8 3rd November 2006 05:04 PM
Heat treated impact driver sockets hardness - Material is Chrome - Vanadium steel peter Manufacturing and Related Processes 6 9th June 2006 07:15 AM
Sol. (Solution) Heat Treated - As pertains to stainless steels - Solution Anneal Cari Spears Definitions, Acronyms, Abbreviations and Interpretations 6 24th November 2005 04:15 AM
The time now is 02:49 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
