Q
quality_ab
I am trying to figure out what could be the best way to depict monthly supplier performance.
I would appreciate any suggestions on how to measure and portray supplier quality.
At incoming inspection lets say we receive a lot with 500 parts. We sample 10 parts.
1) If all 10 are good we allow all 500 parts to go to the assembly line.
2) If even 1 out of the 10 is bad, we reject the entire lot of 500 and consider 500 pieces as defective in our DMR (damage material report) database.
If the 500 parts are allowed to go through to the line (based on the incoming/receiving inspection), if the assembler/operator finds 1 or 2 parts defective, these 1 or 2 pieces are added as defects to the DMR database.
Now at the end of the month when we want to portray the month's supplier quality, we pull up information from the DMR database which gives us the defects per million (DPM).
Parts defective divided by the parts received and the result multiplied by a million. The problem with this metric is that there is a large variation in the data since it is a combination of 500 pieces rejected and 1 or 2 line defect pieces rejected and in some cases the DMR'd pieces are as many as 10000 and give an unnecessarily high number of DPM (defects per million).
Now we do have a seperate metric for individual suppliers. What I am talking about above is one DPM number to reflect supplier performance as a whole.
Thanks in advance!
Thanks in advance!
