Or think of it another way. A very common technique in capability analysis is to apply a Box-Cox transformation to data. In a sense, using a dB scale is like applying a Box-Cox transformation to the data. Without seeing the data is is hard to know if that transformation will make the data closer to normal or not.
Tim
gently posing an alternative view: - just because it's common, doesn't mean you should. This is one area where I certainly disagree with current commonly held statistical practices; I'm a bit old school. my heroes are Tukey, Ott, Seder, et al. Everyone should read Wheeler's article* in the August issue of Quality Digest: "Do you have Leptokurtophobia?" bobdoerring posted the link yesterday...
my answer to the OP's question would be slightly different: he is absolutely correct that a standard calculation of Cpk with dB data would be mathematically incorrect. Because the data isn't Normally distributed AND it's a log scale...HOWEVER, one can assess still assess capability either by determining the proportion of out of tolerance values and working thru the Z table "backwards" [Cpk = Z/3; Z = Normsinv(p)], alternatively you can simply calculate the ratio of the spread of the process to the spread of the tolerance...it depends on what the Cpk value will be used for. Is it defect rate or variation that you are concerned with?
There is no magical correctness to the standard way of calculating Cpk; even with a Normal distribution, the answer is still a point estimate. Processes are rarely static and even slight variations form homogeneity or Normality will yield fairly large differences in the estimate.
The intent is to understand capability; It is not to hit some magical value. Towards that end the run chart plotted against the spec limits is the best first start - it will tell you the most with the least amount of mathematical worries.
If you post your data we can help further...
When you transform the data to achieve statistical properties you deceive both yourself and everyone else who is not sophisticated enough to catch you in your deception. When you check your data for normality prior to placing them on a process behavior chart you are practicing statistical voodoo. Transforming the data prior to using them on a process behavior chart is not only bad advice, it is also an outright mistake." Donald Wheeler, Do you have Leptokurtophobia?, Quality Digest, August 2009
