L
Lincole
My company is attempting to have an ISO 9001 audit. As I found out that one of the material suppliers is not ISO certified, will this affect our auditing chance to get certified?:
The organization shall ensure that purchased product conforms to specified purchase requirements. The type and extent of control applied to the supplier and the purchased product shall be dependent upon the effect of the purchased product on subsequent product realization or the final product.
The organization shall evaluate and select suppliers based on their ability to supply product in accordance with the organization's requirements. Criteria for selection, evaluation and re-evaluation shall be established.
Records of the results of evaluations and any necessary actions arising from the evaluation shall be maintained.
Good point, db with consideration to a specific customer requiring suppliers related to products for that customer. A single customer can not realistically require a company to have all its suppliers ISO 9001 registered if the company makes products for other customers that are different and/or don't use all of the same materials.<snip> If one or more of your customers require ISO registration of your suppliers, then you will have to show that the suppliers supplying product/service for that customer meet your customer requirements. <snip>
Hmmm...I did not know that...
Thanks for this post I am enlightened (--beginner here). I remember a customer auditor from Dallas Semiconductor during a performance audit we had some years ago. He asked who was the supplier of our mold cleaning material (a compression type rubber cleaner) as we just started using it on our semiconductor molds to speed-up the cleaning time and if they are ISO qualified. I remember that my boss (Process Engineer - process owner) replied that the aren't. I remember the auditor continued to check all the documentation about the material and the qualification of the supplier. In the end he agreed not to count the non-ISO certified as a non-conformity but requested to draft a new set of guidelines "for non-ISO certified suppliers" to follow. I do not remember what happened after that.
If I might ask, is that correct? Is there a need to draft a separate rules/guidelines for suppliers?
I'm not sure this is what db is referring to. Having a customer auditor ask a question about "ISO" suppliers (not sure what relevance that has to mold release sprays) is not the same as having a line item in your customers' contracts/agreements to "flow down" ISO certification through the suppliers who are associated with the product you supply such customers.Hmmm...I did not know that...
Thanks for this post I am enlightened (--beginner here). <snip>
