Simple Effective Internal Audit ISO 13485 Audit Check List needed
H
Harmonie - 2009
I need a simple effective internal audit check sheet to 13485. I found a couple in threads but they are a couple years old. The goal is to satisfy 13485's requirement for internal audit as it's been almost a year since last done. Since I am new, I don't have time to put our own together until next quarter and the existing one is huge. It was designed to be done department by department over a period of months.
Welcome any help. It's an emergency. Thanks in advance
G
Gert Sorensen
Re: 13485 audit check list
There are some checklists here in the Cove, but to be honest, if you already have a checklist for your company and it is simply to big to overcome in one audit, then divide it into sections instead. Keep in mind though, that a checklist is not a definitive list, it only makes sure that you check against the standard, it does not necessarily make sure that you check against your own procedures etc.
H
Harmonie - 2009
Thank you! I have only been allocated two calender days to get this done. A more formal but realistic audit program will be developed later.
