The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Design and Development - Process and Product
Forum Username
Search the Elsmar Cove
Custom Search
Monitor the Elsmar Forum
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page  Elsmar Cove Twitter Feed
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Courtesy Quick Links
Howard's
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Reply
Old 20th June 2005, 12:45 PM
LGDeneault LGDeneault is offline
Registered Visitor
Registration Date: May 2004
Thanks Given to Others: 2
Karma Power: 43
LGDeneault has less than 100 Karma points so far.
Warehouse Design Layout - FDA Regulated Medical Manufacturer
Greeting Fellow Eslmar Cove-ers!
We are in the midst of *COMPLETELY* re-doing our FDA Regulated, medical device warehouse and I would like to know if anyone out there has or knows of a really great way to layout a warehouse to incorporate Receiving/Holding/Accepted/Rejected Areas. Also, what is the best way to distinguish these areas and segregation (colored tape on floor, cages, etc.).
We are also using this time to do an accurate inventory audit, since this has NEVER been done quite accurately... Won't it be nice to be able to give the President an answer, "Yes Sir, we can easily build 1000 of the Model #1234!"...
I would really hate to get ALL of the way thru this process and discover a really great and cool way to organize this warehouse...
Thanks, in advance, for your time and consideration!
Best!
LEE
A bit...
Sponsored Links
Old 21st June 2005, 10:47 AM
Scott Catron's Avatar
Scott Catron Scott Catron is offline
True Artisan
Registration Date: Aug 2003
Thanks Given to Others: 54
Karma Power: 113
Scott Catron is appreciated, and has over 1300 Karma points.Scott Catron is appreciated, and has over 1300 Karma points.Scott Catron is appreciated, and has over 1300 Karma points.Scott Catron is appreciated, and has over 1300 Karma points.Scott Catron is appreciated, and has over 1300 Karma points.Scott Catron is appreciated, and has over 1300 Karma points.Scott Catron is appreciated, and has over 1300 Karma points.Scott Catron is appreciated, and has over 1300 Karma points.Scott Catron is appreciated, and has over 1300 Karma points.Scott Catron is appreciated, and has over 1300 Karma points.
In Reply to Parent Post by LGDeneault
We have warehousing and production all in one building - the incoming hold area is just off the receiving dock on the west side of the building, approved components on the north side, production is on the east, product waiting approval is SW and approved product is SE.
Our space is small so there's not much else we can do - not sure it qualifies as a "great way" to do things, but it's simple and easy to explain to visitors/auditors.
We use signs on the pallet racks to lable the various areas. For areas where we don't have racks (and because volume can be variable), we use portable plastic chains attached to stands (with signs as appropriate) to divide areas as the situation warrents on the floor - mostly in the receiving/hold and the finished products hold/approved areas.
Hope that helps.
I don't have a solution, but I admire your problem. -- Steven Wright
I'm a moderator here, so if you need help with something, feel free to ask.
Sponsored Links
Old 21st June 2005, 11:04 AM
jmp4429 jmp4429 is offline
Involved in Discussions
Registration Date: Mar 2005
Karma Power: 63
jmp4429 is appreciated, and has over 700 Karma points.jmp4429 is appreciated, and has over 700 Karma points.jmp4429 is appreciated, and has over 700 Karma points.jmp4429 is appreciated, and has over 700 Karma points.jmp4429 is appreciated, and has over 700 Karma points.jmp4429 is appreciated, and has over 700 Karma points.jmp4429 is appreciated, and has over 700 Karma points.
I can't really give you much help with the layout. It depends on the shape and size of the space you have to work with. You might try doing a spaghetti diagram to see if material and people are travelling an inordinate amount.
I always like cages for stuff that people shouldn't be getting into - i.e. nonconforming or suspect material, or even parts awaiting incoming inspection. It prevents un-inspected or suspect parts from accidentally finding their way into the product. In my experience, without a locked cage, material with unknown status will *always* find its way into production.
Then again, if access is limited enough and your people are conscientious enough to prevent this, I don't see why color coded taped off areas wouldn't suffice. I'm only vaguely familiar with FDA regs, though.
If you are going to use floor tape to mark aisles, different product areas, or whatever in an area with heavy fork truck traffic, I recommend DuraStripe tape over vinyl tape. (No, I don't have any affiliation with them). It's a good bit more expensive than vinyl tape, but lasts so much longer that it ended up being a cost savings. In our shipping and receiving areas, we used to have to pull up and replace all our tape every two weeks. The new DuraStripe stuff has lasted 6 months so far. We've not only saved money on the cost of tape (the sheer volume of the vinyl stuff we went through was incredible) but also the labor to pull up and replace tape. A word of caution with the DuraStripe is that you have to get the floor good and clean before you lay it down.
Hope someone else can better help you with the layout!
Old 10th March 2006, 02:56 AM
BEVel BEVel is offline
Involved - Posts
Registration Date: Nov 2005
Karma Power: 38
BEVel is appreciated, and has over 100 Karma points.BEVel is appreciated, and has over 100 Karma points.
Let Me Help You Warehouse Layout and Mapping
As we're upgrading our distribution warehouse, I came across this site:
http://www.strategosinc.com/_vti_bin..._warehouse.htm
It's for General Warehouse layouting, and I hope that'll help you out. Can't attach the file here. It's 30 MB.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Firmware Validation Protocol/template - FDA regulated Medical Devices industry Medsearch US Medical Devices (21 CFR part 820) 5 24th October 2011 02:06 PM
Our container of sex toys is stuck... regulated as "medical devices" by FDA ? fpindustries US Medical Devices (21 CFR part 820) 19 28th September 2011 07:30 AM
Warehouse Layout Design charliekh Lean in Manufacturing and Service Industries 11 30th June 2010 04:05 AM
Free Warehouse Layout & Planning Guide and Facilities & Workplace Design guide jrubio Design and Development - Process and Product 10 2nd February 2010 02:00 PM
Project Planning Approval Board Approval signatures - FDA regulated medical device danpa Other US Medical Device Regulation Topics 1 18th April 2009 05:40 PM
The time now is 11:07 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
