The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - General Metrology, Measurement Device, Calibration and Test Laboratories > ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories
Forum Username
Search the Elsmar Cove
Custom Search
Monitor the Elsmar Forum
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page  Elsmar Cove Twitter Feed
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Click the graphic above.
Courtesy Quick Links
Howard's
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Reply
Old 11th April 2001, 06:58 AM
Tavares
Unregistered Guest
Posts: n/a
Hehehe... Calibration Room Environmental Condition Requirements
Hello All
I want to known if is possibel what kind of environmental conditions must have a calibration room.
Tavares
Sponsored Links
Old 11th April 2001, 08:58 AM
Al Dyer
Unregistered Guest
Posts: n/a
Lightbulb
It depends on what you are calibrating. For simple items I would start with temp. and humidity.
I'm sure other will have some other types.
ASD...
Sponsored Links
Old 11th April 2001, 12:08 PM
Tavares
Unregistered Guest
Posts: n/a
Hehehe...
The calibration room is to calibrate electrical equipment
Old 11th April 2001, 02:44 PM
Al Dyer
Unregistered Guest
Posts: n/a
I Say...
I sure can't help here, I have trouble screwing in a light bulb!
ASD...
Old 11th April 2001, 03:38 PM
Jerry Eldred's Avatar
Jerry Eldred Jerry Eldred is offline
Registration Date: Dec 1999
Thanks Given to Others: 11
Karma Power: 120
Jerry Eldred is appreciated, and has over 1700 Karma points.
Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.Jerry Eldred is appreciated, and has over 1700 Karma points.
BIG Smile
You need to review the specifications of the items you calibrate, and assure your calibration laboratory (room) area is environmentally controlled to the spec for the unit(s) with the tightest environmental requirement. If you are doing relatively low accuracy electrical calibrations, the requirements may not be that tight. Some examples of tighter specs I have seen are as narrow as 23 Deg C +/- 1 Deg C with no greater than 1 Deg change per hour and %RH 45% RH +/- 5% RH. That is for a higher accuracy environment. I have also seen as loose as 23 Deg C +/-5 Deg C and %RH Greater than 30 %RH and less than 60 %RH. For low accuracy electrical calibrations, your environmental requirements are likely to be closer to the second set of requirements. But you MUST review the specs of the units you actually use. Whatever the manufacturer specifies for those units is the limits you must maintain. There may be units where the manufacturer does not specify environmental limits. Electrical power plant switchboard meters, for example are designed for a very wide range of environmental conditions. The calibrator you use, however, may have much tighter limits. Review all of the items, and spec to meet the tightest one.
Old 11th April 2001, 05:28 PM
DICKIE
Unregistered Guest
Posts: n/a
You might get some help by looking at NCSL recommended practice 14 "Guide to selecting Laboratory environments"
Old 6th March 2008, 08:22 PM
blueicecube blueicecube is offline
Involved in Discussions
Registration Date: Feb 2008
Thanks Given to Others: 43
Karma Power: 30
blueicecube has less than 100 Karma points so far.
Re: Calibration room environmental condition requirements
Am afraid I can't get a copy of NCSL guide. Is there any other standard reference that can help me to guide me to find a reference for environmental condition for electrical lab?
It seems the auditor may need a reference for my selected temperature control.
Old 6th March 2008, 08:32 PM
Stijloor's Avatar
Stijloor Stijloor is offline
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 3,184
Karma Power: 1541
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
In Reply to Parent Post by blueicecube View Post
Hello blueicecube,
This is by no means an all-inclusive resource, but look here, and scroll through this book. Something is better than nothing.
Stijloor.
Thanks to Stijloor for your informative Post and/or Attachment!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
CMM Stylus Calibration - Required to record the As Found condition benvann AS9100, Nadcap and related Aerospace Standards and Requirements 9 31st March 2011 05:07 PM
Analytical Lab Environmental Condition (Temperature & Humidity Control Limit) blueicecube ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 5 17th February 2010 02:51 PM
Initial condition for establishing significant environmental aspects armani ISO 14001 and Environmental Related Standards 1 18th November 2008 11:34 AM
Nonnormal vs. Normal Operating Condition Aspect for each Environmental Aspect? ugurkavi ISO 14001 and Environmental Related Standards 4 7th September 2006 03:40 AM
Inspection Room Environment - ASME standard which addresses environmental controls? Sonjia Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7 20th April 2006 04:50 PM
The time now is 01:11 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
