U
Umang Vidyarthi
Friends,
If the hour and minute hands are equidistant from the 6 hour, what is the exact time?
Umang
Umang
Friends,
Umang
12 .....friends,
if the hour and minute hands are equidistant from the 6 hour, what is the exact time?
Umang :d
It could be 12 AM or 12 PM or 9:15 or 10:10 or anything assuming both hands are of the same length. But I can guess the answer is not as easy as I thought it to be. Isn't it?
12 .....
At 12:00 the minute hand and the hour hand occupy the same spot, and there for are equidistant from the 6 on the clock.Friends,
Umang
Not really: The minute hand is taller than the hour hand (this is a trick question after all).At 12:00 the minute hand and the hour hand occupy the same spot, and there for are equidistant from the 6 on the clock.
1:05, 2:10, 3:15, 4:20, 5:25, 7:35, 8:40, 9:45; 10:50, 11:55, 12:00 You might even say 6:30 because the distance is = 0
Nope, that would make it an ill-defined unsolvable problem. If you want that, you need to mention how much longer the minute hand is.Not really: The minute hand is taller than the hour hand (this is a trick question after all).
Not good enough, that misses over half of the solutions.Disregarding the above and just concentrating on angles, I would say: at any time the minute hand and the hour hand overlap, which would be 22 times in 24 hours.
