alongtain
Hypothetical Question: Let's say I'm CNC machining a 1000 piece order for a new part and it has 3 key dimensions that require "inspection". How would you go about setting up and conducting a process capability study on that job?
I guess the main thing I need help with is determining how many parts to check when performing a Cpk study and at what frequency to check them?
My current method is listed below:
1) First, we dial in the CNC program, setup, speeds and feeds until we're able to produce a good part. The program is then commented with setup, speed & feed info and saved in the DMR (Device Master Record) for the part/part family! It is also referenced in the appropriate operation on our routing for that part (which is created in our shop management ERP system).
2) Second, we develop a detailed inspection report and we inspect the initial order per Z1.4, level II, AQL = 1.0. If we get a repeat order and we know we're in tight control and would like to reduce our inspection frequency, we'll take our Z1.4 results (from the first job) and analyze them to determine if our Cpk is acceptable.
I'm looking for some assistance in devising a simple procedure for conducting process capability studies on the parts we machine and could use some help because I don't have a firm grasp on how to execute a process capability study from a practical standpoint.
