How to make pack bolts and nuts kits with right amount
starupdk
Hi
I am looking for a way to make sure that we pack the correct amount of bolts and nuts and so on into a kit pack.
Do anyone have a way to do this?
we have tried to weigh the bags after packing .. but not safe enough
please help
W
Wilderness Woody
If you are in a high volume production setting, investment in automation may make sense. Use of vibratory bowl feeder lines and sensors (optical, hall, video) can be used to keep track of count to batch the required fasteners.
Small volume kitting can utilize a board or tray template to manually fill cavities with appropriate components and then tip into a funnel for bagging.
K
kgott
Hi
please help
perhaps you could use an electro magnet to lift and drop the required weight which would equate to the right number
