Re: stability & variability studies
Qualtech11: Thanks,
We have conducted the cap studies using results gathered from the last 50 samples, which incidentally covers the last calibration period. The control limit for example is 49.1 Megapascals as a minimum (customer spec, no max limit) and we usually see around double the minimum.
So should we take say 5 samples from each month period and put into Gage r&r sheet (which we do have).
For stability, put 5 samples per month need to go into a
control chart for stability. Which chart depends on your data. Can you post your data in an excel chart? That would help me fab up an example.
The Variability is essentially your gage R&R study. Now this gets ugly, and I am going to explain the "expected" way to do it, even though it is not likely possible to do. First you need to have an idea of what historically your process variation
will be - that is over many days, many lots, many operators, etc. Then you need samples that represent that variation. Forget the spec for a moment. Lets say you expect the
process variation to be 50.0 to 70.0 MPa. Then you need 10 categories of specimens - some at 50 MPa, some at 52 MPa, some at 54 MPa. and so forth. Then, you need to pull some today....then tomorrow....then the next day. Use the data from each day as if each day was a separate operator, then run the gage R&R calcs.
Now here is where the practitioners and the academics may part ways. How do you get such a variety? The academics think you can just sort them out, or make bunches of different lots...which, of course is ridiculous for studying a new gage and for a destructive test. So, the practitioners often will fabricate parts to
represent the variation. For example, if you were using turned dumbbells, you might turn them at different diameters to represent the spread of tensile strengths. It might take some study to get the relationship between the diameter and the expected tensile strength, but it is just a suggestion for trying to dial in the variation so you have consistent parts for the categories.
