Re: Quality System Audit Checklist
Hi. I worked as an FDA investigator (Level II Certified International Medical Device Investigator) for over 21 years- primarily in the medical device arena. Currently, I am a contract international medical device consultant for hire.
There are many areas where you are able to obtain quality system audit checklists. One is contained in FDA's QSR manual- (part of the audit chapter of the QSR manual contained in the website
http://www.fda.gov/cdrh/comp/gmp.html). Others can be obtained for a small fee from a search at amazon.com or ebay.
However, I caution using these "canned" checklists. First, you have to amend them to your system. For example, if the device is one which does not require servicing, and your audit checklist states to audit 21 CFR 820.200 (servicing), then your audit is partially incomplete (because you are not following your approved procedure- i.e. your checklist) + your audit procedure (i.e. your checklist) is inaccurate (because you do not have to conduct any servicing operations).
Second, the use of checklists really limits the audit ability. They can be used as ticklers/guides, but not as sole audit tools because they will cause you may miss items that FDA may catch. If these items are repeats (especially major repeats) noted during the prior FDA inspection, then FDA will add another deviation to the list- an ineffective audit.
