The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Statistical Analysis Tools, Techniques and SPC
Forum Username
Search the Elsmar Cove
Custom Search
Monitor the Elsmar Forum
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page  Elsmar Cove Twitter Feed
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Courtesy Quick Links
Howard's
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
bilateral dimensional tolerances, unilateral dimensional tolerances, tolerances (dimensional or other units)
Reply
Old 28th October 2002, 12:41 PM
David E. Wagher David E. Wagher is offline
Registration Date: Oct 2002
Karma Power: 47
David E. Wagher has less than 100 Karma points so far.
Please Help! Unilateral / Bilateral Tolerances for dimensions with Double Plus or Minus Tolerance
What if any rules apply to the Unilateral / Bilateral Tolerances for dimensions with
Double Plus or Minus Tolerance?
Example: 0.250 -.010 to -.020
Sponsored Links
Old 28th October 2002, 02:15 PM
M Greenaway's Avatar
M Greenaway M Greenaway is offline
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 10
Karma Power: 217
M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.
I dont know about any specific rules, or what context you are thinking of other than in broad statisitcal terms. However I dont believe there to be anything special about them, like any other tolerance you try to set your process mean on the mean of the tolerance. So a double minus or double plus of a nominal value is nothing special, just perhaps makes you think when you look for the mean of the tolerance.
Sponsored Links
Old 28th October 2002, 03:33 PM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Karma Power: 206
Sam is appreciated, and has over 1100 Karma points.Sam is appreciated, and has over 1100 Karma points.Sam is appreciated, and has over 1100 Karma points.Sam is appreciated, and has over 1100 Karma points.Sam is appreciated, and has over 1100 Karma points.Sam is appreciated, and has over 1100 Karma points.Sam is appreciated, and has over 1100 Karma points.Sam is appreciated, and has over 1100 Karma points.Sam is appreciated, and has over 1100 Karma points.
I would question the logic of using a tolerance that - XXX to -XXX. Appears to add nothing but confusion.
Sam Goody
Old 29th October 2002, 08:50 AM
Ravi Khare's Avatar
Ravi Khare Ravi Khare is offline
Involved - Posts
Karma Power: 58
Ravi Khare has less than 100 Karma points so far.
If by uniateral, you mean one sided; then yes there is a rule. If you have a one sided tolerance (..surface roughness, perpendicularity, roundness) then the Process Capability Cpk should be calculated from whichever tolerance that is available.
I assume you are refering to rules for process centering and Cpk calculatons. If you are talking of any other rules please clarify.
Old 30th October 2002, 12:10 AM
Ravi Khare's Avatar
Involved - Posts
Karma Power: 58
This convention evolves from the use of shaft basic and the hole basic systems. Even under the Geometric Dimensioning & Tolerancing, if a 20 mm diameter shaft has to assemble with a 20 mm diameter hole, tolerances on size, location and form will lead to worst case envelopes (Virtual Conditions... as defined by the GD&T standard) on the hole as well the shaft. These virtual condition envelopes will have to clear each other if assembly is desired. The 20 mm nominal diameter hole will then have both the tolerances on the positive side, and the 20 mm nominal diameter shaft will have both the tolerances on the negative side.
This could be one of the explainations. For process control however, as Martin suggests, there is nothing special about it. You have to put your process center on the mean tolerance.
Old 22nd November 2002, 03:17 PM
Karma Power: 47
I thank you all for the responses.
Old 3rd June 2006, 07:10 AM
sjvasudevan sjvasudevan is online now
Registration Date: Dec 2004
Karma Power: 39
sjvasudevan has less than 100 Karma points so far.
Query on that subject
Hi All,
It is just related to this topic. Can any one help me out of this doubt.
I have a Limit Tolerance such as 25.40-25.55. The print says it is special as per customer. Can you suggest how do I fix parameters for capability studies? What is the design intent of MEAN?
Thanks in advance.
Old 3rd June 2006, 09:27 AM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is offline
Cross Forum Moderator
Registration Date: Jan 2005
Thanks Given to Others: 1,985
Karma Power: 1509
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
In Reply to Parent Post by sjvasudevan
Hi All,
Thanks in advance.
The "parameters" are the upper and lower tolerance limits; the nominal is 24.475 (although in this case it does represent the mean of the upper and lower limits, it's still better to refer to it as "nominal" because sometimes the tolerances limits aren't symmetrical). Only the designer knows for sure what the design intent is; you have to assume that if the part doesn't meet the tolerance limits, it won't work.
It is difficult to get a man to understand something, when his salary depends upon his not understanding it. --Upton Sinclair
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Unequal Bilateral Tolerance spreadsheet wanted rnsvasan Statistical Analysis Tools, Techniques and SPC 7 6th April 2010 08:30 AM
Capability calculation on unequal bilateral tolerances? lebelg Capability, Accuracy and Stability - Process, Machine, etc. 5 24th March 2009 09:52 AM
Pre History of SPC plus minus tolerances Caster Statistical Analysis Tools, Techniques and SPC 5 2nd September 2008 04:03 PM
S-type Tolerance - Unilateral tolerance where the desired value is 0 (zero) pinpin - 2009 Definitions, Acronyms, Abbreviations and Interpretations 3 27th March 2008 03:07 PM
Process Capability - Bilateral vs. Unilateral Tolerances kedarg6500 Capability, Accuracy and Stability - Process, Machine, etc. 1 6th February 2006 04:14 PM
The time now is 03:53 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
