MSA is the combination of Gage R&R and calibration. Gage R&R is used to determine if the gage is appropriate for the dimension being measured. Calibration assured the gage is still good, by reading accurately. Only calibration has a time function.
Gage R&R Tips
Picking operators:
You should not need to "test" every operator as a part of gage R&R (although some folks choose to.) The most robust use of gage R&R is to find 3 operators that represent the scope of skill levels on the shop floor. I recommend a new operator (or temporary, if you use them), a longer term employee, and then one considered to be the most "expert" in the gage's use. If you do a good job of picking people with this range of skill levels, the gage R&R should be meaningful.
Picking Parts:
You may not have the luxury of performing gage R&R on every dimension you are measuring. If that is the case, pick those dimensions that are the most critical, the dimensions used to determine adjustments and tool change, the tightest tolerances and the dimensions that are the most difficult to measure due to their location.
