I am implementing inspection test plans for PCBAs. Does anyone know of any key characteristics that should be verified at a minimum? I'm looking in the realm of solder inspection, electrical continuity, component identification and schematic. This is not my expertise, so any examples would also be great.
I know my answer is reaching u a bit late, but would b great if u find it useful still.
for soldering inspection , there are so many broad category and criteria which is clearly defined in the IPC A 610 standrd with pictures. Usually the first run , I have seen is they assemble the components onto the PCB with double sided sticky tape , the component values of the passive compoents will be checked along with their orientation, it should match the pick and place file, the discrete components and the ICs only orientation can be checked. if the placement is as per the layout, then u may proceed to do the assembly. After assembly , if the designer has assigned test points, u can check the designated voltages at these test points, atleast u can check if there is isolation between the power and groundpads using a multimeter or a voltmeter.
Futher tests depend entirely on the product.
Regards,
Harish
