The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Manufacturing, Service, and Business Systems Processes > Manufacturing and Related Processes
Elsmar Cove Forum Sidebar
Custom Search
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Atul's
Symphony Technologies
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
change(s) (general), pyrometry, sae (society of automotive engineers), sae ams 2750 - pyrometry
  #9
Old 27th February 2013, 08:18 AM
wangjianzhi wangjianzhi is offline
Shy Poster (1 to 5 Posts)
Registration Date: Feb 2013
Thanks Given to Others: 0
Karma Power: 2
wangjianzhi has less than 100 Karma points so far.
Please Help! Re: SAE AMS 2750 rev E - Changes Matrix?
Acording to the requirement of AMS2750E, we calibrate the temperature controller by the three points method, it is necessary to include the following items in calibration report:
f.As found and as left data at each calibration point
g. Offset as found and as left (as required)
There are some kinds of condition to use offset or adjustment, i.e. adjust SAT ,adjust TUS and calibration instrument. if the offset field is zero ,when we calibrate it, it’s OK, we do perform TUS for the this furnace after it’s installed on furnace, TUS result is out of tolerance, in order to adjust TUS, a adjustment is input in offset field, then the TUS is OK. After 3 months, when we calibrate this temperature controller, if we don’t remove the adjustment in the offset field, the calibration result will be out of tolerance, in this case, can you give me a example of calibration report ?
  #10
Old 4th March 2013, 09:18 AM
Karma Power: 2
Can someone help?
Thank you very much!!
  #11
Old 4th March 2013, 01:04 PM
dv8shane's Avatar
dv8shane dv8shane is offline
Metrologist
Registration Date: Aug 2010
Thanks Given to Others: 95
Karma Power: 36
dv8shane is appreciated, and has over 1700 Karma points.dv8shane is appreciated, and has over 1700 Karma points.dv8shane is appreciated, and has over 1700 Karma points.dv8shane is appreciated, and has over 1700 Karma points.dv8shane is appreciated, and has over 1700 Karma points.dv8shane is appreciated, and has over 1700 Karma points.dv8shane is appreciated, and has over 1700 Karma points.dv8shane is appreciated, and has over 1700 Karma points.dv8shane is appreciated, and has over 1700 Karma points.dv8shane is appreciated, and has over 1700 Karma points.dv8shane is appreciated, and has over 1700 Karma points.dv8shane is appreciated, and has over 1700 Karma points.
In Reply to Parent Post by sorin View Post
So...the standard is available.
However:
1.Quote from standard "Changes are extensive and not marked" (they are simply not marked, not by vertical line on the left side or by (R) on the right, nada)
2.There is no redline version available.
I assume that for big companies this should not be a problem while for small companies will evolve into a nightmare.
Taking a pyrometry standard (43 pages) and comparing line by line to find the changes is a real, bigger than life PIA.
Anyone know of someone, somewhere that did the comparison?
Check out this link. http://blog.eurotherm.com/ams2750e-u...from-ams2750d/
Smilies are On
AMS 2750 Furnace Instrument Calibration Operating Range Braze Lady AS9100, Nadcap and related Aerospace Standards and Requirements 3 16th February 2012 06:25 PM
How are ISO-17025 and AMS-2750 related? mpbuza ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 2 29th December 2011 11:49 AM
Furnace Classes in relation to AMS 2750 to determine Calibration Interval CJames5 Calibration Frequency (Interval) 1 1st June 2011 03:26 PM
Need New AMS 2750 Compliant Temperature Data Logger QEGirl Manufacturing and Related Processes 8 7th July 2009 06:52 PM
AMS 2750 - Tell me what troubles, specifically, you have had with AMS 2750 ggdjr Various Other Specifications, Standards, and related Requirements 4 15th July 2008 09:51 PM
The time now is 04:57 PM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
