tonya07
I would be interested in getting your advice on how to explain to our customer the proper way to measure the position of the threaded hole on the Optical Comparator. We currently use the Go end of the threaded plug gage. Zero on the gage, move to the top of the part and take dimension, move to the bottom of the part and take dimension. Find the difference in both dimensions and divide by 2. I understand that if you do not divide by 2 you get the total deviation across the diameter but we really want to know the deviation (offset) from center on the radius.
Is this correct?? If so, can you help me better explain to my customer why we divide by 2? They are not understanding our reasoning.
Our customer only finds the difference between both dimensions (they do not divide by 2).
Thank you for your assistance!
